N54 swap
SloanRH4 said:
Awesome project! Out of curiosity, where are you located since you say you can have it street legal?
For the DME wiring, maybe you already know it, but check newtis.info and bimmercat.com, the first one has the repair instructions and wiring diagrams and the second one it's the online catalogue to se which parts are compatible with which model. It's what I used to gather infor for my swap (one a lot easier than yours, from M54B25 to M54B30).
Keep us updated!
I'm from Latvia. Yes, it will be road legal, I had to make a project to get a approval from authorities, bracket has been made by certified company. When the car will be ready I will have to pass government technical inspection, after that special a brake test on a track.
Job in progress
The project still in progress, only left to sort out can-bus communication issues
https://youtube.com/shorts/4ExPCz5CfJY?feature=share
Wow, this is next-level dedication! Hats off to you :thumbsup:
What sort of power do you plan to run? Stock 35i/Si power or a bit more perhaps..? 8)
LittleZ4 said:
Zulu4 said:
Very well done. :thumbsup:
Can you write a "How to" swap engines one day?
Now this would be good!!
Buy new engine
Dump the old engine
… lots of magic and swearing
Results :thumbsup:
Seriously though; swapping the block is probably the easiest bit. All the electronics and system communications is what scares me most in such an undertaking. Impressive stuff this
Buy new engine
Dump the old engine
Results :thumbsup:
Dumping an engine in a hole like you say is the easy bit!! The wizardry that follows is big bit. I'd love one of these in mine. It would be an absolute riot to drive!!
Planning 400-420hp on crank, it will be enough
Buy new engine
Dump the old engine
Results :thumbsup:
lots of swearing not magic :D
So I see you've done good stuff on the handling side..what about the brakes? Or are you planning to use a 'chute? :rofl:
Front Z4M rotors, 335i calipers and ferodo 2500 pads, rear stoptech rotors, ferodo 2500 pads. HEL braided hoses and motul 600 liquid
Splendid! :driving: :thumbsup:
LittleZ4 said:
Is there an update on this one? I'm quite eager to see how it's turned out! :D
Finally no limp mode, test drove a few weeks ago, wheels were spinning through first and second gear.... crazy car. Still working on can-translator, but car is ready for certification and planned for end of next month. During the test got a ticket πŸ˜€
Hey, sorry for bringing up old thread, but wondering what software you used to program dme to e85 chassis
