ph001 said:
Admittedly I’m only listening on my phone but I can’t hear any noises on that video that would concern me particularly. Sounds pretty normal to me.
This thread is getting pretty long now, perhaps you could recap the problem you are experiencing and what you have tried so far.
Sure thing - RECAP:
Symptoms
- Hesitation/jerking when accelerating from low RPM, most prevalent when in a high gear
- Juddering/surging when going constant speed or applying light throttle, particularly around 1500-2000 rpm
- Strange behaviour when decelerating in gear, similar to jerking when accelerating but more random and like someone is poking the throttle as the car slows
- Various noises, high pitch marble-like rattle towards the rear of engine
- Blowing-like sound from exhaust on hard acceleration, very subtle but either sounds like a leak or gasses not escaping properly
Parts replaced
DME update to latest versions
Both VANOS solenoids
Valve Cover gasket
Eccentric shaft sensor and seal
MAF sensor
VVT Motor Gasket (found vacuum leak around it)
Intake manifold gaskets
6 Bosch Coils
6 NGK Spark Plugs
CCV and 3 main CCV hoses
5w30 LL04 Oil and filter
Inner DISA valve
Cleaned VANOS check/non-return valves
Troubleshooting
Listened to all injectors, all function with the same pitch when solenoids are activated. Primed the fuel rail with injectors installed but out of the cylinder head to check for leaks, no leaks. I haven't tested the spray pattern but have run several doses of injector cleaner.
I have investigated a number of parameters and conducted adaption resets/VVT relearn cycles. Parameters include o2 sensor function, all look normal, rough running which all look within spec, VANOS positions look to be good from reference/actual positions with some lag but unsure what is considered normal.
Without making this post long in itself, my current train of thought regarding the cause of this problem relates to the cylinder head, here's why. The behaviour is very mechanical in nature, it happens at the exact same points in the rev range without any significant perceptible deviation. The behaviour manifests during deceleration, not in the exact same way, but similarly, during which time injectors, spark, air for combustion and related hardware are not a factor. Which leads me to the projected cause. I think there is a problem with (likely one) lifter, intermediate arm, valve spring or valve on the exhaust cam side. This would fit with the noise, lack of power low down, hesitation, jerking at constant throttle and even when decelerating. If a valve is sticking or only opening partially then I believe these symptoms would fit. I suppose this could also happen with slight damage to a valve. The reasons I am hesitant to try and diagnose the problem along that path is I feel the problem would likely be present during the entire rev range, there would be rough running data in diagnostics to support this.
Next steps
Compression test (I guess if a valve issue is present, compression will be low, though only if it is sticking open)
Just leave it because I'm tired thinking about it -.-
