Sgr74 said:My roof is bubbling up and is out of its paint warranty. How difficult is it to remove the panel as I guess it’s easier and cheaper to get it painted if I take it off the car?
Pbondar said:I’m under the impression it’s not very easy at all..
It’s a “next year” job. I miss the days when you could go to a scrap yard and do your research on another car before touching your own.B21 said:Sgr74 said:My roof is bubbling up and is out of its paint warranty. How difficult is it to remove the panel as I guess it’s easier and cheaper to get it painted if I take it off the car?
It would be much cheaper in time and effort to remove the seals on the sides of the front shell and mask off the rest of the car.Sgr74 said:My roof is bubbling up and is out of its paint warranty. How difficult is it to remove the panel as I guess it’s easier and cheaper to get it painted if I take it off the car?
:thumbsdown:Christopher72 said:It would be much cheaper in time and effort to remove the seals on the sides of the front shell and mask off the rest of the car.Sgr74 said:My roof is bubbling up and is out of its paint warranty. How difficult is it to remove the panel as I guess it’s easier and cheaper to get it painted if I take it off the car?![]()
You'd have to maintain the tension on the mechanism with long zip ties or the specialized BMW tool built for that specific function, heat and remove Loctite glued bolts that should be replaced afterward, ensure that the positioning spacer counts are remembered, and remove the electrical and hydraulic connections from the shell. In reinstalling, you'll have to realign the front shell and adjust for spacing tolerances and correct seating against all adjoining seals.:thumbsdown:
This is what I hoped it would be. Simply unbolt it. I’ve seen them for sale on eBay so it can’t be that difficult.flybobbie said:Well using some logic, the interior panel pulls off and roof is probably just bolted on.
Looking at old video looks like 4 bolts.
Sgr74 said:This is what I hoped it would be. Simply unbolt it. I’ve seen them for sale on eBay so it can’t be that difficult.flybobbie said:Well using some logic, the interior panel pulls off and roof is probably just bolted on.
SV8Predator said:Pbondar said:I’m under the impression it’s not very easy at all..
Maybe he chooses to go to on with this endeavour at this time and do the other things, not because they are easy, but because they are hard…
It was carefully placed on cushions, so no gravel contactChristopher72 said:I'm amazed it still shines after being shiny side down on gravel!
