Beeacon said:I think it is jsut a normal Z4, not an //M.
Normal as in se suspension or normal as in sport (m springs) suspension? :?
Smartbear said:Beeacon said:I think it is jsut a normal Z4, not an //M.
novaz4 said:There was a z4 suspension matrix somewhere and it shows non m sport suspension is stiffer than M sport in comfort mode, that's what made me decide to just go for M sport, esp. because I like the trim more.
That being said, I'm on OEM summer run flats on 19" rims, and in cold weather < 60 degrees, even in comfort it's pretty harsh. When it's a bit warmer outside things are more comfy.
novaz4 said:Hmm, thanks ... Yea I remember being slightly confused of all the the different options. I take it M-Sports Package (P337A) didn't come with the Adaptive M Suspension? I checked my VIN and it does have S2VFA Adaptive M suspension added.
Busterboo said:Hallelujah, brothers and sisters! I do declare, Brother John has finally seen the light! Hallelujah! Praise the Lord!john-e89 said:... I found drifting away from the door pillar tyre pressures really upsets the car, even if that’s pressures for 18’s, so I run those pressures after some experimenting.![]()
A good question.john-e89 said:Busterboo said:Hallelujah, brothers and sisters! I do declare, Brother John has finally seen the light! Hallelujah! Praise the Lord!john-e89 said:... I found drifting away from the door pillar tyre pressures really upsets the car, even if that’s pressures for 18’s, so I run those pressures after some experimenting.![]()
Off topic slightly but do you not find 18’s and non flats too soft in comfort Buster...? Also have you ever tried 19’s for comparison on non flats..? Pure idle curiosity is all as as I said I find MPSS’s almost too soft on 19’s.
Busterboo said:A good question.john-e89 said:Busterboo said:Hallelujah, brothers and sisters! I do declare, Brother John has finally seen the light! Hallelujah! Praise the Lord!
I came from a 911 on Pirelli P Zero Rosso* - the best tyres I've every known - to the 35iS on Bridgestone runflats - the worst. The runflats went in a month. At that point, I had the chance to change the 18" wheels, too, but knew that the OE 19" cracked sometimes.
I didn't believe they did because of "hard tyres", but because of poor design. So, I returned to what I knew to be good: Pirelli P Zero on 18". Both have proved to be very good, indeed.
(*The P Zero Rosso are black glue, but for Porsche only and last 10k miles at most. The P Zero are the next best thing, but last x2+.)
Coincidentally, the recommended tyre pressures for both the 911 and 35iS are F36 & R44.
