Excellentenuff_zed said:No, that's already the shorter sport one.
cheers I just cut the new ones down to 60mm...gotta be better than what was on there.NaweedMustafa said:You will need the shorter auxillary bumps for lower/M sport setups
Fronts: 31336778545
Rears: 33536770350 (this part number comes with the protection sleeve attached to it. Part 3 + 4 on RealOEM diagram)
Sorry??TIMMOS29 said:cheers I just cut the new ones down to 60mm...gotta be better than what was on there.NaweedMustafa said:You will need the shorter auxillary bumps for lower/M sport setups
Fronts: 31336778545
enuff_zed said:Sorry??
You asked and I said your photo was of Sport ones, but then you cut them shorter anyway??
No my original affirmation was incorrect. On the rear there is a significant difference, but on the front it is not so much.NaweedMustafa said:enuff_zed said:Sorry??
I just ran downstairs to check all the parts I got. Indeed that is the shorter one. I hope he didn't cut it after my message
My post was more of an affirmation to confirm with the part numbers
enuff_zed said:No my original affirmation was incorrect. On the rear there is a significant difference, but on the front it is not so much.NaweedMustafa said:enuff_zed said:Sorry??
The sport one doesn't have the waisted part below the ridge as shown in the OPs photo.
Sport should be 60mm, so cutting this one down was ok.
[ref]TIMMOS29[/ref], apologies for any confusion caused.
Why didn't you just get the correct ones?TIMMOS29 said:Im learning and managed to do one shock tonight post incoming soon!!!
good pointScooba_Steve said:Why didn't you just get the correct ones?TIMMOS29 said:Im learning and managed to do one shock tonight post incoming soon!!!
:lol:TIMMOS29 said:good point
i waited so long for the parts from auto doc and loads of different references came up i gave up…….Scooba_Steve said::lol:TIMMOS29 said:good point
Just wondered, were they not available, part number mix-up etc.![]()
It would only have any effect if you cornered very hard, enough to bottom out the damper. Highly unlikely in normal driving. And even if you did, the foam rubber bump stop would compress so it's not as if you suddenly make the suspension rigid. I suspect in reality the difference in length of those two bump stops would never really be tested unless you were on a track.j24 said:Sorry for the slight thread hijack with an uneducated question - but would installing standard bumpers rather than the sports bumpers actually impact ride height at all?
I.e If rest of the suspension components are the lower “sports” suspension, would it have any bearing on ride height? Or would it be purely a handling thing?
The bumpers are at the very top of the spring travel. So they shouldn't affect ride height. But they would make contact sooner.j24 said:Sorry for the slight thread hijack with an uneducated question - but would installing standard bumpers rather than the sports bumpers actually impact ride height at all?
Put the correct part number in and both types came up? Or just put in car model and there were many?TIMMOS29 said:i waited so long for the parts from auto doc and loads of different references came up i gave up…….
enuff_zed said:It would only have any effect if you cornered very hard, enough to bottom out the damper. Highly unlikely in normal driving. And even if you did, the foam rubber bump stop would compress so it's not as if you suddenly make the suspension rigid. I suspect in reality the difference in length of those two bump stops would never really be tested unless you were on a track.j24 said:Sorry for the slight thread hijack with an uneducated question - but would installing standard bumpers rather than the sports bumpers actually impact ride height at all?
