Clingfilmed the engine while I located a stud extractor and a few new bolts.Liam22 said:Currently dealing with a sheared valve cover bolt.
Liam22 said:I had the opposite problem where the DSC was constantly on! My preference is for ABS on and DSC off which I achieved by disconnecting the steering angle sensor. However, prolonged disconnection seems to cause a soft brake pedal so it's occasionally reconnected.
FTR, my Sport button and DSC buttons both operate as they did before I started removing things.
No idea, and it's still not 100% confirmed. My hunch is a bug in the ABS unit firmware. I'll be putting a switch on the dash to control power to the steering angle sensor, as I'm getting too old to be upside down in the footwell.Vanne said:Any idea how it causes a soft pedal?
Look familiar?Liam22 said:I'm looking [...] to fit bracing between the boot lid and the bodyshell so that the rear wing is solidly mounted
Liam22 said:These are 325mm discs.
Reasons:
1. The calipers expect 28mm thick discs and OEM is 25mm. While they would work, I don't want to risk pistons falling out with worn pads.
2. I didn't want to buy new 3 sets of rims - these will still fit under 17" rims
3. Weight. OEM is 8.9kg each, 325mm M3 discs are 7.64kg each. So that's a total 2.5kg saving and met my <£100/kg target.
Liam22 said:The new brake adapter brackets turned up this week. Positions the caliper 1.5mm further outboard so the M3 discs run smack in the centre.
The total saving over OEM is 6.3kg!!! Unbelievable...
The only snag with the new brackets is that I've now run out of wheel clearance. 3mm spacers now on order.
The brake pad position on the M3 discs is absolutely perfect. No underhang.
It opens by removing 2 bolts from the inside with *a lot* of extension bars! But yeah, there's nothing in there so I don't expect to do that very often.Vanne said:So the boot will be unable to be opened at all?
I increased spring rates front and rear after getting the car to race spec and with the aero package.Wursle said:how did you find the setup after installing the rear wing? did you spec the coilovers for the rear wing or have you put the wing on before?
The roll cage picks up the rear top mounts. See page 14.Wursle said:now you have swapped to a true rear coilover are you planning to strengthen the rear top mount pickups?
The K-system.pro website said that the E46 brackets fitted both non-M and M3 discs. That was wrong so they made me a custom set. You would be able to order either now that they have the measurements I gave them! Great company to deal with.Wursle said:how did you spec the K System brackets/brakes
