Jingles White Z progress thread!! (PICTURE HEAVY)
Haha thanks mate, going on holiday in a few hours for a week so once in back I'll continue my modding.
HIDs ready to go in, fang protectors ready to go on (just need couple of screws) and air scoop ordered!!
ok.....
RPi scoop should be delivered today
HID kit delivered and ready to fit
Fang protectors still waiting to be fitted
and now my holiday is out the way i can start planning my next mod.
still not convinced about my current ride height (front looks fine but the rear is DEFO sitting higher)
i think its probs to do with the set of rear M Sport rear springs i got,were from a 3.0 so my car has less weight to compress them when sitting there normally.
so altho i really want to order some new wheels next week..... i suppose its best i sort the ride height all round 1st.
also noticed when in the front wheel arch couple of weeks ago the dust guard ribbed thingy isnt sitting correctly on the front damper so theres a high chance there knackered and need replacing anyway...
so.... as i have already added bilstein B4 shocks at the rear earlier this year i need to know which front shocks should i get to match them (just get some front B4s??) and then which set of springs to go all around to either match M Sport lowering or slightly more, maybe some H&Rs or Eibachs? (would the B4s be able to handle lower than the standard M Sport height??)
any ideas on prices would be a help
sorry for the slow progress guys, now xmas is out the way the modding will carry on!
ive added some HIDs but will do a write up when i do a few more bits...
currently got a stud conversion kit to go on, new front 330 big brake conversion with 325mm discs, RPI scoop, and in the process of ordering new suspension (springs/shocks and possibly bushes) and new wheels so over next few weeks this should start up and get added to nicely :D
got some new 330 calipers and gave them a very quick once over, need a proper good clean then paint, and new seals etc but hopefully i can get these back into good condition...
sorry for the slow progress on this guys, i seem to have abandoned my whole "do 1 job at a time" idea and have loads going on at once haha
installed HIDs (photos and details to come)
stud kit at home ready to go on
rpi scoop being sent in the next week or so then installing
in process on cleaning up then installing new front brakes (and discs/pads)
in process of buying new front shocks
in process of buying new springs all round
in process of buying new wheels
in process of buying new tyres
slow progress but going to pick up pace fast once all parts start arriving!!!
had to put the brakes on hold, couldn't get the pistons out and will probs need new 1`s anyway so will sort that later.
instead ive ordered the below:
H&R springs £142 delivered - http://www.amazon.co.uk/29269-1-Perform ... B002NV9J1A
Bilstein B4 front shocks £157.20 pair delivered - http://www.itectuning.com/48-bilstein-s ... k_absorber
Meyle HD front top mount x 2 £40 (£50 but used discount code for 20% off) - http://www.itectuning.com/suspension-pa ... mount.html
Meyle HD boot kit (dust covers and bump stops x 2) disounted as above from £17.28 -20% to £13.82 - http://www.itectuning.com/suspension-pa ... t-kit.html
51717012721 front left air duct - £22.55 from Dealer
31306779487 Hex bolt with washer x 2 - £8.56 for the pair from Dealer
fingers crossed i can at least start doing some of the work once parts arrive this week so i can FINALLY start progress in the thread again!
sorry for the slow progress people...... gonna pick up pace again now tho!!
few bits to go on..... :D
did this a few weeks ago but not had time to write it up...
passengers side headlight kept letting water in, removed headlight to investigate and found a couple of brackets had snapped off, ordered a repair kit and set about repairing the large hole..
broken lug and hole:
plastic cut to size:
all sealed up water tight and fixing lugs replaced:
had enough of the poor light output from the standard Halogen lights so decided to upgrade to some 55w HIDs in 6000K
removed light and gave them a good clean and dry out:
reflector lamp removed to allow better cleaning etc:
stripped down for a good clean:
mounted the ballast on the inside, in this area:
rough location of all wires etc when fitted and replaced:
finished light output:
Top = standard lights/bulbs
Middle = standard lights/upgraded Osram night breaker bulbs
Bottom = 55w HID kit with 6000K
Nice neat repair job on the headlight :thumbsup:
I've swapped in osram nightbreakers - they certainly make a big difference, I raised the headlights too.
Your garage pics give a good indication of increased light, I certainly notice the difference on the country roads.
about time i got around to fitting the springs...
1st up the rears as they are easiest!
old spring next to new spring:
the 2 next to each other:
old uncompressed spring height:
new uncompressed spring height:
new spring ready to go on:
new springs on and fitted:
next up, the front springs AND new Bilstein shocks!!!!!
old shocks and springs:
old shock/spring set up removed:
old shock/spring set up ready to be disassembled to reuse rubber pads etc:
old knackered shock next to shiny new shock:
old springs next to new springs:
new shock/spring set up trial fitted:
new shock/spring set up fitted and bolted in:
a random photo of some friends helping, with the horses in the background:
and my dog was helping/protecting us from my aunts peacock...... but she kept getting scared everytime it fluffed its feathers up haha:
