Hey fellow Z4 enthusiasts,
I'm experiencing a rather frustrating and intermittent issue with my 2003 3.0 E85 Z4, and I'm hoping someone here can provide some guidance or share similar experiences. The problem I'm facing is that both the car's head unit and accelerator pedal stop working intermittently, but then start working again after a few hours or days. I've tried the usual troubleshooting steps of turning the car off and on again, but it doesn't make any difference.
To investigate further, I decided to read the car with a scanner, and it provided me with the following 4 error codes:
2806 DME: Cruise control - time limit of data transmission reached.
27B5 DME: Inlet Camshaft - Activation.
MAF sensor issue (I'm already planning to replace this).
279C DME: Thermostat - Map Cooling Activation.
Based on my research and the symptoms I'm experiencing, I suspect the issue could be related to a faulty voltage regulator in the alternator. I've had a few other strange electronic issues in the past, and despite having a new battery that I recharge regularly, these problems persist. Therefore, I'm planning to order a new MAF, alternator, and potentially a throttle body and camshaft position sensor.
However, before I go ahead with these replacements, I wanted to reach out to this knowledgeable community to see if anyone has encountered a similar problem or has any additional suggestions for the list of parts to consider. I appreciate any input or insights you can provide.
One thing worth mentioning is that my Z4 is an automatic, and when I put it into gear, it moves backward and forward without any issues using idle revs. However, when I try to accelerate by flooring the pedal, there is no change in the RPM. This leads me to believe that the transmission itself is fine. It's also unusual that whenever the accelerator isn't working neither is the head unit and when the head unit is working the accelerator is fine.
I'm eager to get this issue resolved and continue enjoying my Z4 to the fullest. Thank you all in advance for your help!
Best regards,
Andy
Best regards,
Andy
