no crank intermittent
winchman
another but different from what I could find
2004 3.0 82K miles 6spd
runs fine - battery app 6 months old
drove 60 miles shut down - returned 9 hours later to no crank
(always the same = all lights and things work - remote key unlocks - radio/dash/.... all normal but - no crank at all - no clicks -- nothing)
next day same - no crank...
tried second key - same
tried to jump start - same
push started - immediately started and ran fine - no error lights... - drove it around the parking lot
shut down - no crank
next day same - no crank... push started - immediate start - drove around the parking lot
push started... drove around lot - shut down - no crank
next day no crank
push started - immediate start - drove home 60 miles - no issues
shut down - started immediately as normal
- shut off then cranked again - immediate - normal start
- shut off again immediate normal start
to me this is the starter - but most posts point to the ignition switch first... does the push start and intermittent start make a difference or still ignition switch first?
thank you for your expertise!
I'd always suspect the starter before the ignition switch. Grab some jump leads and put 12v direct to the starter and see if it turns.
Then you have your answer.
