JamesL said:Thanks for this Shipkiller. Have just spent a long day following these instructions and almost have a completed job. Had a moment of panic when putting the roof back in and it no longer folded all the way manually (even with the override pulled out), but I think this was just some air in the hydraulics as once I reattached the wiring, the roof seems to work perfectly. Wouldn't have been able to do it at all without this how-to.
A question for you though. How did you get the hoop back in the clips? We found this really hard and I'm hoping that once a few of the bolts are in, I'll be able to lever it in from inside the boot.
Tim182 said:I am busy replacing my motor. I noticed that the connectors for the hydrolic pipes have changed sides.
On the new motor 11 13 is now where 12 14 was on the old motor and 12 14 is where 11 13 was. Has anyone else noticed this?
BettyBmw03 said:Tim182 said:I am busy replacing my motor. I noticed that the connectors for the hydrolic pipes have changed sides.
Has anyone else experienced this, if so what did you do?
BettyBmw03 said:So, I have officially replaced the motor with a new motor. Sealed the insulation with silicone and it should be cured by now. Going to try to drop the roof back and and PRAY IT WORKS!
