Respect and thanks to Shipkiller.
I have just completed the replacement or the motor and put everything back together. It doesn't work! But hey, no-one ever said it would be easy, so here we go again. Just a few comments though, which may help others, and comments I haven't seen anywhere else.
My pump came with 2 wires (blue & green) about 50mm long, on the opposite terminals to the original blue & green wires. I don't yet know which is correct but I have reversed the connections inside the car to save removing the roof, but it makes no difference. I'll post again when I know.
The infamous W clips are easy when you know how!! Put them in from the INSIDE of the car. You can't see what you're doing but can feel your way reasonably well. You could try using a mirror or a beautiful assistant, but I did it without either quite quickly.
Getting the bolts back in the 'hoop' was a nightmare because they aren't really long enough to grab the thread. I managed to get the front 5 in with a lot of pushing and a 'G' clamp, but the 2 at the sides I had to replace with longer ones.
No-one seems to mention the root cause of the problem of motor/pump failure, which is water build up in the drainage well. Even without all the tape, water will not get into the pump housing unless it builds up in the well; and even WITH all the tape, it will still get in if the water DOES build up! There is only 1 small hole in the well, and it will get blocked with gunk, allowing a build up. So, while you have the top off, drill a few more holes about 25mm away from the original one to improve drainage.
More to come when I crack it...
Completed in one afternoon. Cleaned the drains while I was in there.
