335dan said:Coded my e92 335d using your guide and it works!! Thank you!!!
Timmyboybunter said:Just out of interest, how much effort is retro fitting a heated steering wheel? (and how effective are they in real life!)
Hi Dave, would love you to retrofit cruise on mine, just need to plan as its a 280 mile drive to get to youAnubisZed said:Timmyboybunter said:Just out of interest, how much effort is retro fitting a heated steering wheel? (and how effective are they in real life!)
It's do'ableand without too much effort (dependent on you "effort" scoring lol).
You'd need.....
Heated steering wheel (obviously)
Correct slip ring
Lower steering cowl panel
Switch
various connectors and some wiring.
The wheel, slip ring and cowl are not cheap and not always that easy to find.
Apart from the physical fitting and wiring then you'd need to go through the coding stage as well.
And as for how effective they are, well I'd say they are as good for your hands as the heated seat is for you bum!!![]()
I've fitted cruise to four now with heated wheels and I always test that it works once the battery is back on (as well as the new stalks, just in case!!) so I've had the chance to feel them working (as I don't have it on my own car) and can honestly say they are awesome, but you don't need them on for long.
Now comes the problem though, when I say not cheap...… last time I saw a wheel for sale it was £380, the slip ring is about £80+, lower cowl is around £60 - £80, if it doesn't have the switch with it then you could be paying another £40 for that as well, so as you can see is it worth all that outlay for the sake of wearing a pair of gloves??!! :?
Zed Baron said:Hi Dave, would love you to retrofit cruise on mine, just need to plan as its a 280 mile drive to get to you![]()
Timmyboybunter said:Thanks, very useful - definitely is a lot of money but I do have the roof down in any and all temperatures. I have the vents aimed PERFECTLY at my hands in the straight ahead position so generally they do stay nice and warm (not a fan of gloves) but the heated wheel sounds like a nice luxury. It will also stop me snapping at people when they change the air vent angles![]()
Timmyboybunter said:Well, a german seller just accepted an offer of £155 including postage for a set of cruise control stalks including cowl, heated switch and slip ring - so I'll tuck these away in the loft until I get time to do some proper research (quick Google tells me if it's not fitted from standard, the required wiring isn't present in the steering column but that's literally 30 seconds worth of skim reading) and a wheel pops up.
Stick me down as a willing guinea pig if the opportunity ever arises![]()
Timmyboybunter said:Cheers, I'll probably take you up on that - I'll keep an eye out for a suitable wheel, but as I'll want an M-Sport one (I find the standard one a bit skinny) it may take a while. One sold a few months ago on US Ebay for $200 though so there's a glimmer of hope.
cvhuis said:Did yesterday the retrofit with al stalk for 70 euro included the Lower steering cowl panel from a E90
After the programming it seems to work, but when i turned the steerwheel i got errors.
RFM and steering and so on.
I have a E89 3.5i with Sdrive. so any idea whats wrong?
Did the coding again, but no effort.
