HOW TO; Convert Angel Eyes to BRIGHT LED's
Wow that looks to be a significant improvement! Is it an even illumination though? No large decrease in brightness as the distance around the ring from the bulb increases? Computer doesn't detect any bulb issues?
Nice and even. They are 200 lumen compared to the 40 or so of the standard bulb. No errors.
Mike
Mike
Sounds perfect - I'm going to have to give this a go too! Thanks for sharing, Mike!
not to rain on your parade mike, but if you drill two small holes, the light can come out as a bayonet. Then replace with a bayonet led, saves on dremeling/soldering
http://www.ebay.co.uk/itm/BA9S-CAR-BULBS-LED-ERROR-FREE-CANBUS-6-SMD-XENON-WHITE-233-T4W-SIDE-LIGHT-BULB/271892115025?var=570728365295&epid=1441719825&hash=item3f4e086e51:m:mybGIYmDgKAt968Mkocsn1w
Yup, was well aware of that, however I had these LED's lying around, and I wanted something brighter, so it was a no-brainer, no cost job.
Mike
Have you or anybody else tested a bulb like you linked?
My experience of unbranded eBay bulbs is that they are usually rubbish and don't last..
My reasoning on these is that if Halfords see fit to give them a 5 year warranty, the failure rate must be very low.
Mike
That's a fair call. But if a quality BA9 bulb is easier to retrofit than your option (which you yourself said was done simply because you already had some of the W5W bulbs) then it's surely the optimal solution?
Yeh, I've had the bulb I linked in for a year now and not had an issue, like Mike says it doesn't have five year warranty, but for the low price it's worth it imo! Much better than buying a £30 whole new side Light unit like bmw intended
Cheers but I was more interested in the light quality (brightness, illumination evenness, colour) ;)
I'll take a picture for you tonight
Hope this helps, definitely seem dimmer than I remember them being when the xenons are on too
Cheers mate! I've got some eBay units on the way so we'll see how the go ;)
Just wanted to check did these need coding out or completely error free?
Unsure on the eBay ones but mine were fine with no errors.
Mike
Sorry I missed this, I coded out the lights when the sidelight initially broke. Not sure if I coded the warning back in when fitting them
So I tried out a similar bulb to what Philbo linked but it's just as dim as the stock halogens: http://www.ebay.com.au/itm/2-x-BA9S-Bayonet-5-SMD-Canbus-5050-LED-White-Interior-Dome-Map-Car-Light-Bulb-OZ/263285449298
They were also really blue looking :/
It seems that when looking for a suitable LED bulb you need to check that it's a decent wattage/lumen output and also look for a warm white colour. I'll grab some others to try!
