Apologies, that's should have said *bagsZedebee said:It depends what a “back” is in this instance.
Thank you for your message. I will explore all of those you have mentioned. I really hope its nothing to do with the diff as I assume that could get expensive :headbang:Zedebee said:No, I regularly do the weekly shopping in mine () and the boot never gets hot. Could heat be leaking in from a sticking brake calliper (does one of your wheels get very hot?) or a failing diff. Or is the amp getting hot, if you have one (in the battery compartment pre-facelift, or on the firewall post-facelift)?
Thank Martin, I will take a look to make sure. Pretty sure I have seen the heat shield there. Assume I would have noticed that on a number of occasions by now. I am thinking this is something more intermittent.enuff_zed said:Do you still have the heat shields fitted above the exhaust?
