andysat said:Been told it could be just the short runs i have been doing that has clogged the cat,and all thats needed is a few good run outs to clear it out,anyone believe this?
andysat said:Been told it could be just the short runs i have been doing that has clogged the cat......
andysat said:Thanks mate-can you notice any difference?
andysat said:Sorry ,i just wanted to add that my indy advised me strongly not to put an additive in the petrol.![]()
good link, taLillywhite said:Interesting web-site that cross references theses codes:-
http://www.endtuning.com/bmwcodes.html
Hey good point mate,never thought of thatGeorgio said:Out of interest Andy have you tried seeing what the actual emissions are like from your exhaust using one of those MoT probe gizmos?
Just a thought as I had the light just before my MoT last week and the exhaust was a clean as a whistle.
'If' this code is supposed to be a total CAT failure, then surely the engine would be pumping out all kinds of bad shite that can be read by the probe?
If on the other hand the readings are fine, then it's not the CAT and you'll have to start looking at things like the pre/post O2 sensor routing etc.
It sounds to my unexpert gut feeling that you might have a rubbing cable or suchlike which could explain the intermittent fault.
andysat said:Hey good point mate,never thought of thatGeorgio said:Out of interest Andy have you tried seeing what the actual emissions are like from your exhaust using one of those MoT probe gizmos?
It sounds to my unexpert gut feeling that you might have a rubbing cable or suchlike which could explain the intermittent fault.-i would of thought my indy would have tho?-like i have ststed on here it shows no signs of loss of power,no knocking,popping sounds,no sulphur smell,can i just pop into a garage and ask to pay for a reading?
