15v high Voltage & 002E97 fault code
jonnymac
 Northern Ireland
Hi All
I need a little advice and guidance.
I was driving home yesterday and the battery warning light came on twice in about 5 miles, I drove home (10miles) and put a multi-meter on the car, it read just over 15v at idle on after a longish drive which seemed to high. I connected a small handheld car battery tester directly to the battery and it said the battery was good with a state of health 79%.
I assumed the high voltage output was a faulty alternator and replaced it today and the voltage is currently reading 15.3v at idle on a cold engine. Now im lost as what could be the problem, the cable & connector at the alternator look good as do all the battery connections. I use the car daily and it's not giving any other indicators, slow starting, won't hold a change etc and the battery is still testing good today. Im assuming that the voltage should be 14.8v or less at idle.
E89 3.0 2009
jonnymac said:
Hi All
E89 3.0 2009
Is it worth checking your multimeter out on a different car?
No point chasing all sorts of theories if it turns out your kit is out of calibration.
Thats was worth a shoot, i plugged in icarly and ran a test through its live data and its sadly showing the same voltage.
As far as I know the car can vary the voltage depending on the state of the battery, the z4 is very susceptible to a “dickey” battery, so although it shows 79% it could well be on its way out and the car is trying to rapidly charge it, how old is the battery? I’ve just replaced mine again after 6 years.
You might be on to something, i took photos of the battery tester yesterday and its state of charge was 79%, this evening its showing 40% charged, the battery's been disconnected from the car since i removed the old alternator yesterday, that doesn't seem normal at all. I'll replace the battery tomorrow and use carly to register it.
I can't see a date on the battery but i haven't replaced it in the 3+ years ive owned the car.
New battery..make sure it’s coded if needed, then registered..then see what gives..
jonnymac said:
Thanks for the advice, a new battery fixed the problem.
95% of all ‘issues’ on E89s disappear with a new properly registered coded charged battery :thumbsup:
