2016 will have the latest fuel injectors so that should be one less thing to worry aboutTOMGREEN413 said:Thanks for sharing, the car I'm thinking about has 39k on the clock and is 2016 model year so l would assume its still in good shape ?
Very interesting and great advice. Yes this is the car, as you say , not keen on the wood but l could over look it. Price information is useful, I was thinking nearer £17k but I'm not very clued up on prices so your assessment is helpful. What does WBAC mean? Sorrymatsmith749 said:Is it the blue one in Kettering?
Looks decent - ticks most of the boxes. Has cruise / the nice 19in wheels / heated seats / parking beepers / idrive.
No heated steering wheel though! It has wood trim which is a personal decision if you like that or not. Not sure if has adaptive dampers.
Just be aware that the WBAC is about tuppence on these at the moment - if that matters.
£20k would be about what I would have expected from a dealer sale 18 months ago for a car in this spec & condition (which looks great BTW) - but more recently these have plummeted like everything else.
£15-£16k tops - especially as it's a private seller.
tiglon said:Pre-emptively changing the water pump for the first time next week as it's showing signs that it might be on the way out (but still drives fine). Not a particularly expensive job, in the grand scheme of car maintenance.
Christopher72 said:tiglon said:Pre-emptively changing the water pump for the first time next week as it's showing signs that it might be on the way out (but still drives fine). Not a particularly expensive job, in the grand scheme of car maintenance.
Good luck in the work, decent midrange DIY -- If you are going through the effort for the pump, it's a no-brainer to change other nearby failure points, the thermostat and Mickey Mouse flange (11537541992) as well. Important not to reuse the aluminium bolts for the pump or flange. If you're not planning on replacing all of the rubber coolant hoses as I did, at the least replace the 'U' shaped hose (11537545665). It suffers heat from the turbos and can be a failure point. No reason to connect your new pump and therm together with an old hose prone to failure.
My experience: https://z4-forum.com/forum/viewtopic.php?t=143542 if it helps.
