A lot of modules are failing just lately and they seem to go in batchesHansdampf said:Besides ponzy and me...everybody else can easly code the SIM85 unit? or read at least the coding?
It's really strange...
[ref]colb[/ref], [ref]bigwinn[/ref], if [ref]ponzy[/ref]'s situation is this desperate, maybe you should PM him with your alternative ideas. :wink:ponzy said:Maybe the dash out and black tape is the way forward,as some suggest.Not sure how effective a 22 year old airbag would be anyway.![]()
Well it just worked for me. Apologies if anything I previously posted has misled you but I only just learned this myself this afternoonponzy said:so does that mean I need to get a 920 same as original,unfortunately I've just bought a 67 but I can always sell it on again.
If you have an 811 you need to check the .his file to see what it is paired with then select that option in Winkfpponzy said:would coding the 811 to 5147 work , at what point did you manually enter 5147
Just a thought............. Go through the process again, but this time, in WinKFP, select 6965147 and see if that works?ponzy said:Yes, original faulty sim, part number 6935920. Purchase a used unit part number 6939811,after edit vin and flash process using WinKFP, as per crib sheet, its now given it a part number 6962767 it also gives the physical hardware number as 6939811 which can be seen via INPA Ive checked with realoem and all seem exchangeable.
No, I have used other numbers and they have worked. It is only the 2767 that seems to cause any issues. At least............. for me.ponzy said:I thought that,so tried but it errors out incorrect zusb when winkfp goes to flash sim so aborts,looks like it has to be the same part number or it won't work,real oem referance compatible modules,maybe works if they are brand new units un- programmed.
Forget that. Think you said you’ve already tried that.enuff_zed said:What happens if you try to flash that one again to a 5147?
