No, just horrible steering.poortomsacold said:firebobby said:He will want to go down the expensive route, it's not his money!ryushe said:You're absolutely right of course. Already tried getting to the bolts last weekend, but while I seem to be able to reach one (it turned), I just can't get to the other (not enough space for hands + tools). Took out the lower air duct and everything, still no space (LHD car). By the way, it's two T40 torx bolts in my case, would probably be a lot easier if I could grab the bolts directly instead of having to use a socket wrench :/
Initial call to this gentleman was to get the ring adjusted, but his argument is that sticky steering is something different from this specific issue (literally 'stuck' steering wheel during turns vs. tiny adjustments to the steering wheel while driving straight between certain speeds). He claims it's due to issues with the ESP motor incorrectly reacting to sensors readings, which would require a 'new' steering column.
I just can't work out exactly how what sounds like an electronics issue can be related to a full mechanical replacement...
I had sticky steering, it was like the car was suicidal and wanted to crash
I adjusted the ring some years ago and it was an instant fix, the car became a pleasure to drive.
Morning. Aside from the sticky steering itself where the steering wheel sorts of locks into position, did you have any other sorts of steering issues - loose handling at speed, etc?
enuff_zed said:Think I quite like being enuff ZEN![]()
poortomsacold said:enuff_zed said:Think I quite like being enuff ZEN![]()
Haha bloody predictive text at it again! You were snuff_zee when I first typed it!
:evil:Yup! How to spend your Saturday evening, trying to think a jammed spanner out from 150 miles away.Chengy said:Huge thanks Joycey. Did the adjustment today, counterclockwise to tighten my steering as it felt light/floaty especially at speed and it feels so much better now. Actually needs more force to get off centre which is exactly what I wanted.
I used this which worked a treat - Silverline 633787 Fixed Head... https://www.amazon.co.uk/dp/B000NBPIP8?ref=ppx_pop_mob_ap_share
Just make sure that you have the steering column fully extended and down, otherwise you may spend an hour trying to get the spanner out of the tight space..thanks again enuff_zed!
I am based in West Midlands if anyone wants help with the adjustment.
Cheers!
enuff_zed said:Yup! How to spend your Saturday evening, trying to think a jammed spanner out from 150 miles away.Chengy said:Huge thanks Joycey. Did the adjustment today, counterclockwise to tighten my steering as it felt light/floaty especially at speed and it feels so much better now. Actually needs more force to get off centre which is exactly what I wanted.
Cheers!
[ref]Chengy[/ref] even refused to rule out my suggestion of Semtex at one point.![]()
Hey Chengy I may need to take you up on that offer at some pointChengy said:Huge thanks Joycey. Did the adjustment today, counterclockwise to tighten my steering as it felt light/floaty especially at speed and it feels so much better now. Actually needs more force to get off centre which is exactly what I wanted.
Cheers!
Special Kay said:Hey Chengy I may need to take you up on that offer at some pointChengy said:Huge thanks Joycey. Did the adjustment today, counterclockwise to tighten my steering as it felt light/floaty especially at speed and it feels so much better now. Actually needs more force to get off centre which is exactly what I wanted.
Cheers!![]()
Try using an 8mm bi hex ratchet ring spannerryushe said:Long shot, but I just can't seem to get this sorted out. Made a special super low profile tool with a T40 torx bit to get to the harder to reach bolt, but no joy in actually loosening the bolt and adjusting the ring. With all the friendly folk on here, anyone in NL that has done this before and would be willing to help me out?
Good suggestion, will give them a call, thanks!Barty said:Haven’t done it myself, but ProCar in Zwolle do it all the time. They can help you out no problem
Joycey said:Special Kay said:Hey Joycey, I've just been reading through your handy work. Having recently bought a coupe, my journey home was dampened by the travel/play I was experiencing in the steering wheel around 60mph. I was thinking worse case scenario or replacing or reconditioned steering rack, but this thread has restored some confidence in BMW. Once I've got it on the road (probably next spring to summer) this will be one of the first things I will be addressing. I just wanted to say a huge thank you to you and all other contributors for all your analytical and problem solving skills. I'll be eternally thankful.![]()
Your welcome, if your local more than happy to make the adjustment for you. Plenty of space now to help out.
Uniped said:It's not sticky steering, it just makes micro adjustments when I'm doing 40-60mph and driving is less than enjoyable
I think I'm in the same boatUniped said:It's not sticky steering, it just makes micro adjustments when I'm doing 40-60mph and driving is less than enjoyable...
