When you remove oil filter there is a small o ring on plastic shaft.
Apparently this blocks a drain hole to sump.
Can a oil pump be used through this hole to drain engine oil, or is it not direct to sump.
https://blog.fcpeuro.com/how-to-fix-a-leaky-oil-filter-housing-on-an-n51-n52-n54-or-n55-engine
