So there is water behind the passenger seat, which I've now established is coming from the roof motor well, which is full of water. (The roof motor has already been relocated to the boot
The question is, what is the best way to deal with this:
- poke something(?) down from the top to clear the drain hole?
- find someone with smaller hands to poke the same something up from underneath, to clear the drain hole?
- remove the rubber grommet from the drain hole?
I'm inclined to remove the rubber grommet (assuming this is possible), as I see it being a permanent solution. But will this cause any future issues of any kind?
cheers
cheers
