Yeh, centre cubby hole is a good one to check as the switch actuator can break off. Put your mobile in there doing a video to check! Also, not locking the car actually takes more drain from the battery as it doesn't go into full 'sleep' mode with doors unlocked.
Buy one of these which you can simply clamp around one of the battery wires to check current. It should be less than 0.1A when car is asleep..... https://www.amazon.co.uk/Multimeter-Tacklife-Auto-ranging-Continuity-Capacitance/dp/B01N014CTB/ref=pd_sbs_328_4?_encoding=UTF8&psc=1&refRID=P4ZT794ZEEJEHQG793MJ&tag=z4fo-21
