Deepseaskateboard
Which cap does the oil actually go in?
Step away from the car :lol:Deepseaskateboard said:Which cap does the oil actually go in?
Nictrix said:Step away from the car :lol:Deepseaskateboard said:Which cap does the oil actually go in?
Smartbear said:Nictrix said:Step away from the car :lol:Deepseaskateboard said:Which cap does the oil actually go in?
I didn’t reply because i didn’t think he was being serious!![]()
Deepseaskateboard said:Smartbear said:Nictrix said:Step away from the car :lol:
I get it serviced at BMW, I literally have no idea!
You are just trying to confuse him nowSmartbear said:Deepseaskateboard said:Smartbear said:I didn’t reply because i didn’t think he was being serious!![]()
It’s the black cap on top of the cam cover.
Deepseaskateboard said:enuff_zed said:Is this an April Fool?Deepseaskateboard said:There is an oil reservoir on the driver side at the front of the engine.
If you remove the cap whilst engine is cold,
(Don’t do it after a drive!)
There is a float, which acts similar to a dipstick.
The instructions are moulded into the plastic.
I was so taken aback I had to go and look at mine.
That is the cooling system expansion tank surely?
Don't go topping up your oil in there!
Ah, sorry it’s coolant!
I thought it was part of the oil system.![]()
SV8Predator said:Deepseaskateboard said:enuff_zed said:Is this an April Fool?
The internet at its finest.
<<There is an oil reservoir on the driver side at the front of the engine. >>
The only problem is that someone may read this and think it's correct.
Apparently the mods wanted to put it in the 'delete' file but it ended up in 'favourites' by mistake.Deepseaskateboard said:SV8Predator said:Deepseaskateboard said:Ah, sorry it’s coolant!
I deleted the original post, but can’t do anything about all the quotes.![]()
Probably should can this thread!
enuff_zed said:Apparently the mods wanted to put it in the 'delete' file but it ended up in 'favourites' by mistake.Deepseaskateboard said:SV8Predator said:The internet at its finest.
Probably should can this thread!![]()
Deepseaskateboard said:enuff_zed said:Apparently the mods wanted to put it in the 'delete' file but it ended up in 'favourites' by mistake.Deepseaskateboard said:I deleted the original post, but can’t do anything about all the quotes.![]()
Haha, next topic, what happens if you pour oil into your coolant!
Chippie said:Deepseaskateboard said:enuff_zed said:Apparently the mods wanted to put it in the 'delete' file but it ended up in 'favourites' by mistake.![]()
You get plenty of mayonnaise, although you can use most of it up on your salad as it’s the middle of summer![]()
So maybe if you have to top up the oil you should start with 'lettuce pray'.Deepseaskateboard said:Chippie said:Deepseaskateboard said:Haha, next topic, what happens if you pour oil into your coolant!
I do keep an emergency salad in the boot, you never know.
Tee Hee - very good sirenuff_zed said:So maybe if you have to top up the oil you should start with 'lettuce pray'.Deepseaskateboard said:Chippie said:You get plenty of mayonnaise, although you can use most of it up on your salad as it’s the middle of summer![]()
I do keep an emergency salad in the boot, you never know.![]()
Oh, and very glad you are taking all this in the spirit it is meant.
