No its not electronic mechanical.
Afaik it is a gerotor or shear pump actuated clutch pack, so different in workings than a standard clutch pack LSD (the progressive clutch pack, the most commonly used type nowadays, there are also clutch type lsd's with a fixed spring tension and fixed lockup).
A standard clutch pack diff engages by the drive force put on the diff (the planet gear axes are pushed against ramps that press on clutches), and the gerotor/shear pump actuated diffs engage by speed difference between both wheels. The gerotors /shear pump is an oil pump that is driven by the speed difference on both wheels, and that pump actuates the clutches. I don't know if it uses a separate oil reservoir in a blatter or the oil in the diff for the actuation mechanism.
The difference between the two is that the first locks up as soon as power is applied, and the second locks up as soon as one wheel starts to spin.
So there are 3 'types' of passive clutch actuated lsd's:
Fixed ratio (fixed tension spring presses on clutch, the friction force between the 2 wheels is always the same)
power actuated ratio (clutch pressure/lockup increases as throttle/power is applied more&more)
Speed actuated ratio (clutch pressure increases as turning speed difference between wheels (=loss of traction) increases)
But it's certainly not a controlled electronic-mechanical diff. There are not control wires going to the diff. I think that was first applied in the F10 M5 and the later F80 m3/m4
