kis said:Cheers fella.
Info is out there, just needs to be compiled by someone![]()
For what it’s worth I’m sure Style 32 are the lightest (or one of the lightest) wheels out there for e46/e85 cars... maybe worth looking into?![]()
kis said:18” Tyre Sizes
Changing tyre sizes is also an option for those with 18” wheels. This could be because of a complex suspension and low spring set up, or simply to save some money on opting for slightly thinner tyres. The fronts can be changed from standard 225/40/18 to 215/40/18 (narrower) or 215/45/18 (narrower and for increased sidewall… comfort). Rear wheels as standard are 255/35/18 and this could be changed to 245/35/18 (narrower) or 245/40/18 (narrower and for increased sidewall… comfort).
If you do opt for increased sidewall on the fronts or the rears there is always a chance you may experience some rubbing. Lots can affect this such as road conditions, condition / age of suspension, whether you have lowering springs, if you’ve got spacers, etc. etc.
Mind Bomb said:kis said:18” Tyre Sizes
Its taken me most of the evening reading your excellent post Kis. I'm particularly interested in the above section on increasing the sidewall size for a little added comfort. (i have a 51 year old spine!)
if i change the tyres, currently the standard sizes (225/40/18 & 255/35/18) with the intention of increasing the sidewall to 45 and 40 respectively, do i have to have the narrower tyre sizes you mention above?
ie. can i run 225/45/18 & 255/40/18 or must they be 215/45/18 and & 245/40/18 (is the narrower size recommended to lessen the chance of rubbing?)
I appreciate i could make life simple by changing the wheels to 17 inchers but the 18s i currently have looks so damn cool ( style 135 i believe)
cheers, Dani
Mr Tidy said:Well the original BMW MV2s were 8Jx18 fronts and 8.5Jx18 rears and were fitted with 225/40x18 front tyres and 255/35x18 rears.
So if those are the wheel sizes your OH's car has those are the sizes it would have originally had unless you want to go for 245/40x18 rears for a bit more comfort which "mr_wilks" does, and given the number of Z4s he has owned I'd probably go along with that!
If the wheels turn out to be replicas (or are even genuine MV2s but all fronts) and are all 8Jx18 I'd put 225/40x18 tyres all round. I'm sure I read somewhere that a "square" set-up usually handles better with less understeer.
I certainly wouldn't worry about 225s not giving enough grip. My daily is a 330i SE and only has 225 tyres all round but never feels short of grip!
But those are just my thoughts FWIW.
Whatever you go for will be better than Landsails. :lol:
