Hertz 165 ordered! :yeah:
Pbondar said:Well done, as you say an exceptionally good exercise in cost effectiveness..definitely plays to the 80/20 design rule..![]()
I’m sure re-coding to Hi-Fi then re-visiting your various controls would be the cherry on the cake.. at least it would satisfy my curiosity![]()
Argyll Andy said:Well done sir, I think this is a masterclass and fantastic guide for those wanting to upgrade the 6 speaker system.![]()
I had some advice from Peter and seriously toyed with upgrading mine but wasn’t sure where to start. I would’ve done this straight away following your lead if I’d still had the car
Loved reading this post, and if I ever take the plunge and buy an E89, I will most certainly revisit this post!mr.tourette said:Then I just used velcro to attach the amp to the trim, added a little double sided tape to keep the rca extensions from flapping about
Z4C_er said:Loved reading this post, and if I ever take the plunge and buy an E89, I will most certainly revisit this post!mr.tourette said:Then I just used velcro to attach the amp to the trim, added a little double sided tape to keep the rca extensions from flapping about
Just wanted to add though, I hope that velcro is the super grippy automotive stuff (like 3M dual lock):
....because I foresee that Amp succumbing to gravity in no time flat. Also, polypropylene doesn't take to adhesives very well.
If it were me, I'd take advantage of those mounting points and bolt it to the trim. If you're worried about damaging the trim for resale prospects, you could always plug the hole later with a fir-tree clip.
mr.tourette said:Z4C_er said:Loved reading this post, and if I ever take the plunge and buy an E89, I will most certainly revisit this post!mr.tourette said:Then I just used velcro to attach the amp to the trim, added a little double sided tape to keep the rca extensions from flapping about
Its supposedly heavy duty, its still there this morningThe amp is pretty small and lightweight, cant be even 500 grams I would think..also those rca leads are attached with a slice of no more nails on a roll and that s**t is going nowhere without a hairdryer, some wd40 and patience, if gravity gets to it it won't be going far
Your post has had me going out to check and in all honesty it seem rock solid, I'll keep an eye on it though and maybe add a pair of small bolts, one in each diagonal corner ..thanks for the tip
Silverstar said:Many thanks! I'll have a go at them over the next few days. Those Hertz C165 got cancelled apparently the store I bought them from didn't have stocks and couldn't tell me when they would arrive so I found some Hertz MP 165.3 (same thing but a little better) for 23 euros more, they arrived this morning and my they are heavy little things over 1kg each! Looks like real good quality speakers! I am still pondering what to do about the amp, I want to fit an Apple Car Play box first and see how that wires in before deciding on the amp.
Silverstar said:I found this interesting article online about stereo imaging and soundstage. It kind of explains BMW's reasoning for our attenuated signal on the rear channel:
https://www.crutchfield.com/S-MWAnDvoTBil/learn/car-speakers-soundstage-imaging.html
