Maybe. Im no expert on amps tho, Im guessing you will be able to amp up everything better using 2 amps but the only way to truly bypass the head unit setting will be to code to hifi. If you are happy to push your budget tho then it may well work very well, Pete would be better positioned to advise you here. I can say though that on my little vibe amp the benefit is huge, whilst the increase to the rears is still clipped by the head unit they're still very audible. You want the sounstage biased to the front of the car anyway so pushing too much to the rear may not be beneficial.
I think the speakers you have invested in dont need a mass of amplification to bring a positive result
Im currently pondering an active underseat sub wired direct to the battery which will then plug into the rca on the vibe, this (technically) should relieve the mid woofers of heavy bass duties and allow more power to the fronts from the vibe and cleaning things up even further.. food for thought
