I would quite like to do this, however that ^^^^ reads like a foreign language to me, i guess i need to start learning about ncs expert, if anyone local ish to N wales/Chester can help. with this it would be much appreciated.Nick9one1 said:Colin_E said:Do you have any info on how to do that? Harsh with over-boosted treble has been exactly my experience from a door speaker upgrade (Audison mids & tweeters). My 'compensation' settings are moderately boosted bass, a negative on the treble and a small shift on fader but a coding setting is something I'd like to try.Nick9one1 said:Have you coded the car to HiFi?
The standard setup has boosted treble to overcome the lack of tweeters, it will probably sound a bit harsh until you do (Mine did).
It will make a huge difference.
It was quite some time ago that I coded it so its difficult to remember! :headbang:
In a nutshell the process is;
add $676 to VO, then FA_write in FRM and CAS.
Then, using NCS, with the profile "expert", code the following modules :
CHOST
CAPPL
CGATE
CAUDI
CTUNE
I found a post I made in 2018;
After step 8 I had to choose 'chassis', 'CAS' before it would take my VIN.
After step 19 (FA_Write on CAS) I chose change ECU, and performed the FA_Write on CIC.
this ^ seems to correspond to these v instructions;
Plug in cable to OBD port and selected usb port
Run NCSexpert
Click "file" and select "load profile" and select "expertmode"
Click "VIN/ZCS/FA
Click "ZCS/FA f. ECU
Select chassis type "e89"
On choose ECU select "CAS"
After your vin is shown select "enter FA"
Ensure VIN shown is correct and select "OK"
Enter $676 and then select "add"
Then scroll down and select "£676" and select "OK"
Then select "Back button"
Then select "F4 Process ECU"
Then select from drop down list "CAS"
Then select "F2 Change Job"
Then select "FA_WRITE" and click "OK"
Ensure CAS is shown on "Get Coded" and FA_WRITE shown on "JOB NAME"
Select "F3 Execute Job"
Im about to dig into YouTube and see if I can pick up a little knowledge
