tintoverano
no worries, it is auto what I had, have
So you have this on the windscreen?....tintoverano said:no worries, it is auto what I had, have
AnubisZed said:
To answer in order....Fresno82 said:Picking up on this thread, I have auto wipers (with the green LED and rain sensor). Do you really have to press this button in every time you get in the car? If so, is there any way to set this on as default?
Pondrew said:Adding to the 'default off' theme, I found out only yesterday that the PDC defaults to 'off' unless you select reverse, when it then comes on automatically, but then switches off over 10mph ish when driving forward. I thought there was something wrong with the front ones when I parked in a car park.![]()
Every other car I've had with auto wipers and F&R PDC have always been 'on' unless you turn them off.
And the irony is that the 'start-stop' defaults to 'on' so you have to physically turn the bloody thing off.![]()
Nanu said:It was explained that it was the fitted sensor that hiked the price up.
The two are not related chumtintoverano said:I don't have auto-lights, but have auto-wipersAnubisZed said:If you have Auto Wipers then you also have Auto Lights.
Auto Lights switch...
AnubisZed said:Only the sensor mount (the purple coloured lens and translucent sticky) is part of the windscreen, the actual sensor unclips from it, but they must be making it part of it just to hyke the price up even more..
Now I've just done a quick on-line quote (all from the same company) for these screens and surprisingly the one with the Rain Light Sensor was cheaper than one without!! And the one with the RLS had 2 options, with equipment or without, so presumably that means with the RLS attached or just the mount.
And BMW never sold the Auto Wipers and Auto Lights separately, they are part and parcel of the same package, so if you have one then you have both. Checking the options list and the VO coding list there is not one without the other, as it's called the "Rain Light Sensor" for a reason and there is only one VO code which is 521.... but then I've already given all this information 8)
Are we talking auto-dip lights or auto-on lights here??B21 said:AnubisZed said:Only the sensor mount (the purple coloured lens and translucent sticky) is part of the windscreen, the actual sensor unclips from it, but they must be making it part of it just to hyke the price up even more..
The Font of Knowledge clarifies the position…![]()
As a side note, a friend asked whether it was relative easy to retrofit an auto dim/dip mirror…?
