Smartbear said:You’re going to wonder what to do with yourself once all this kit’s been fitted & fettled! I suppose you could always drive it around![]()
Rob..quite so..good job I put my name down for all those trips in 2022
Smartbear said:The series 1 Elise was offered in mustard yellow, not much wrong there![]()
B21 said:So slow progress..got the new NGK coils to replace the dodgy, podgy Hella coils..should be fitted on Monday...
I updated the vehicle order to remove the electronic damper option, (had a fault code and disabled sports mode warning) added the performance brake option for the 6 pot brakes, coded the new index 12 injectors with their flow rates and then uploaded the MHD Stage 2+ map which on 98 RON should be good for about 420 HP with the VSRF de-cats and Wagner EVO FMIC.
Also coded the DCT box using xHP with a stage 2 map.
After all that realised that IF you use xHP then in MHD you are supposed to code using gearbox = manual ( I guess to avoid some overlap)..so will have to re-flash the DME, after the initial flash it only takes about 5 minutes for subsequent flashes.
I'll take the car to the dyno before Christmas if possible to see how it all looks before the TTE500 turbos and other bits go on.
Took a few pictures of the wheels and brakes..looking a bit dirty so not the best looking shots..
Argyll Andy said:B21 said:So slow progress..got the new NGK coils to replace the dodgy, podgy Hella coils..should be fitted on Monday...
Those wheels look well with your car, great combo![]()
B21 said:Argyll Andy said:B21 said:So slow progress..got the new NGK coils to replace the dodgy, podgy Hella coils..should be fitted on Monday...
Andy, glad you like them, I’m not so sure, yet, maybe once everything is clean and polished…don’t like dirty cars…
Uh oh! Spoiler alertB21 said:The joys of buying from China..
Ordered a rear C/F spoiler on the 31st August 2021..went missing for weeks..so after 6 weeks I ordered a second one on the 15th November.
Then on the 27th November the missing one arrived.. 88 days later..23 days late..
And voila...the second one arrived today.. 16 days after I ordered it..21 days early..
Really must be more patient..
Wonder what I can do with two c/f spoliers?
enuff_zed said:Uh oh! Spoiler alertB21 said:The joys of buying from China..
Wonder what I can do with two c/f spoliers?![]()
B21 said:enuff_zed said:Uh oh! Spoiler alertB21 said:The joys of buying from China..
Lined myself up for that one..![]()
Peter, you're always looking for the next level.peeblezZ4 said:B21 said:
Glue one on top of the other - extra downforce!![]()
enuff_zed said:Peter, you're always looking for the next level.peeblezZ4 said:B21 said:Lined myself up for that one..![]()
Surely you can use the pair for some kind of DRS set up?![]()
You could post one for sale on here for a tenner plus postage and I'm sure someone may take it off your hands out of pity.enuff_zed said:Uh oh! Spoiler alertB21 said:The joys of buying from China..
B21 said:I’ve got too many buggars chewing at my heels..I’m not giving them a DRS opportunity![]()
Flyingfifer said:![]()
Good to see you with an engine that actually fills the bay Peter![]()
Question, whats the difference between an index 12 and index 9 injector?
