PDJ said:
I my car from the oil pressure gauge i get between 15 and 20psi when hot at tick over and 55 to 60psi at revs over 4000rpm when hot
Interesting. The reason I ask, is that I saw in another topic (I think on zpost) that there are also s54 rodbearings available with larger clearance (so larger gap). From ACL bearings (HX bearings so 6b1569hx for the s54)
It took some digging but the enlarged gap is 0,001", so 0,025mm
And on the one side that makes sense. The stock rodbearing clearance for the s54 is 0,030mm to 0.070mm (in comparison, for the m54, which has a slightly smaller bearing it's 0,020mm to 0,050mm)
And there are lists with data regarding oil thickness and bearing clearance.
So for instance this article:
https://k1technologies.com/blog/bearing-clearance-and-oil-viscosity-explained
and this one:
https://www.enginelabs.com/news/what-i-learned-today-bearing-clearances-vs-oil-viscosities/
Mind you, all american articles, so measurements in inch.
And for thick oil, like 10w60 they advice quite the bearing clearance. Roughly between 0.0028" and 0.0033", so between 0,071mm and 0,083mm.
Considerably larger and adding 0,025mm clearance makes sense. (based on my experience, the clearance that you measure is pretty much inbetween the min and max value, so for the s54 that would make for a typical 0,050mm)
But again, US articles, US engines (usually a far cry away from european and japanese engines...)
And if I look at the low rev oil pressure, that is already pretty low. Rule of thumb is 20psi at idle (ok, also mainly based on US engines).
And enlarging rodbearing clearance typically gives lower oil pressure in low revs (there is more time inbetween strokes to refresh the oil film as the hole is pushed shut it's a pulsating feature unlike main bearings where the flow is continuous, which lower the oil pressure equally no matter what the revs as bearing clearance stays the same).
So I wonder if fitting rodbearings with larger clearance would be good or bad. If oil pressure at idle was higher maybe yes.
