R60BBA said:The more important question here is - how many S54s do you know that have gone bang due to rod bearing failure?
If I had a pound for every time I’ve read “Wow, caught them just in time!” :lol:
AndyBeech said:R60BBA said:The more important question here is - how many S54s do you know that have gone bang due to rod bearing failure?
What you see on forums is the experience of people. If the rodbearings wouldnt wear, you'd see more bearings not showing copper or bearing wear. But the fact of the matter is that the vast majority of engines being opened up do show extensive wear on the bearings.R60BBA said:No it doesn’t, because 70% of what you see on forums is people’s problems with their cars, which is not a true representative of ownership for the masses.
Mr Tidy said:I'd love to see the difference in the viscosity of the oil at different temperatures
PDJ said:It will not be seeing any oil though as it is for food colour that goes in coke beer and whisk to name a few products we make colour for
Mr Tidy said:What if the boss is out?
PDJ said:Do you drink any of the above?
No he isn't and neither are you, bearings that can wear out in as little as 50k, whether an M engine or not are something you should be concerned about. If your not concerned, fine but bad advice is still bad advice.R60BBA said:Meh, he’s right. They are not as much an issue for S54’s than they are for other M engines such as the S65.grannyknot said:Make sure you show those bearings to your to regular guy, he needs to stop saying that about s54's. Looks like you got them just in time.
Bearings can last 200,000+ miles as long as the car is looked after (ie regular oil changes and the car is warmed up properly).flimper said:Not sure if this has been mentioned before, but if you got the rod bearings done at say 60k, would you then have to get them done again at 120k or are the new bearings better quality now?
NLW73 said:do people go for OEM bearings or the King race style bearings? not sure if there is much difference and whether the king ones are harder wearing and can take higher revs?
PDJ said:Don't know of anyone on a second set other that race engines
R60BBA said:Bearings can last 200,000+ miles as long as the car is looked after (ie regular oil changes and the car is warmed up properly).
GuidoK said:PDJ said:Don't know of anyone on a second set other that race engines
That's because most people here hardly do any miles (usually less than 10k miles/year), and/or usually flip the cars relatively fast. I mean people that hold on to the same car longer than 10 years are a minority on this (and most) forums.
Bad installment will give a different wear pattern than the usual wear pattern.TomK said:Of course the outcome could well depend on how they were installed so can hardly be conclusive I guess. I'll post them up when done.
