ABS DSC Regulating System failure
RalftheCat
New member
Hi All,
I have 3 yellow warning lights on the dash of my 2004 e85 and the owner's book suggests it's ABS DSC Regulating System failure. Has anyone had experience of this? What's involved and how much is it likely to cost to get it fixed? Is it a job for a BMW Specialist, or can my local (very good) garage do it? Thanks in advance.
It could be one of several things so first step is get the codes read.
ABS sensor on the wheels, one of the two sensors on the master cylinder, the yaw sensor under the seat, just for starters.
Whereabouts are you? Several members have code readers and some may even help to fix it.
As above …usual culprit is the sensor …especially if car has been standing or driven through large puddles.
Which lights are on? Usually if it’s a wheel sensor you get the tyre pressure light on as well.
But still need the codes first to be sure.
Bit too far for me though I’m afraid
