Greetings fellow Z4 fans.
I recently acquired a 2007 Z4 E85 with a known ABS issue, namely the common trifecta of lights on the dash. After checking powers and grounds etc, I determined that the ABS / DSC pump was bad, so it's now away with ECUTesting being repaired. It looks like a repair may have been attempted previously - doesn't look great as you can see in the picture below.
However, I also have an issue with the mounting bracket for the pump. As you can see in the picture, the ABS pump is attached to the mount but the mount is just "hanging out", i.e. is not attached in any way to the body.
I've looked online and cannot find any schematics or pictures of the correct mounting. I'm not even sure this is the correct bracket? I see on other Z4s, prior to 2007, there is a diagonal stabilising bar, however, this doesn't appear to fit the 2007 model from searching on ebay. Can anyone please clarify or provide a picture of the correct mounting?
When searching ebay, there seems to be no listing for pump brackets for 2007-or-greater cars.
Any advice would be much appreciated.
TIA
TIA
