Recently bought a car that's been on this forum for the past 10 years or so. Originally owned by Roundozo, then by JamieZ4c before being sold recently to GWest44 and then to me. I bought the car unseen whilst on holiday but my pal test drove it for me so knew it was fairly straight.
As a bit of background I've been searching for a fun car to drive that handle track days and be fun on the road. I used to have a clubsport spec V8 M3 which was wonderful on the road and track but the running costs of the thirsty V8 started to become a pain. Since then I've had a couple of other cars which seemed to fit the bill but were lacking one thing....RWD. After driving my mates 130i at Bedford recently I decided to find a Z4 Coupe which could be used on track.
M3 build can be seen here:
https://forums.m3cutters.co.uk/threads/cheap-e92-m3-for-road-and-track.259123/
A few weeks ago the car I am in today came up for sale and I snapped it up. Spec as I bought it is as follows from the advert:
2006 Z4 E86 3.0si
It's the sport model, and benefits from a Bilstein B12 kit. The water pump, clutch & DMF have all been replaced and the wheels are Style 32's from an E46 that have the identical staggered 18" set up to the original style 108 wheels.
One of only 34 UK cars with the triple black spec of Sapphire Black exterior, Oregon black interior and Piano lacquer dash. It's had lots of work done over the years including:
Electric water pump replaced
Handbrake shoes replaced
HID kit installed
Bilstein B12 kit fitted (shocks and springs)
Front and rear anti roll bar bushes replaced with Superpro bushes
Front and rear drop links replaced, Meyle HD
RTAB replaced
All four top mounts replaced
Upgraded Meyle HD wishbones fitted
Polly bushed front control arms
De-badged
Aux kit installed
Stubby aerial
Ram air scoop
Black kidney grills
Clutch and DMF replaced
CDV delete
Prop shaft doughnut replaced
Gearbox mounts replaced
Gearbox oil changed
Diff oil changed
Style 32 lightweight alloys
New boot (BMW corrosion warranty)
Drilled and Grooved Disks all round
Copper painted callipers
Headlight washers replaced
LED sidelights
LED Number plate lights
The last service was an inspection II carried out about 2000 miles ago by a BMW specialist so everything appears to be in good working order from a filters/plugs point of view.
There is some significant rust on the rear panels which will get sorted in time but to be honest I want to get the mechanicals all correct first.
First thing to do was to get it home and detail it. It was washed, clayed and single-stage polished by DA before a coat of spray sealant applied.
View attachment 188878Untitled by
Damien Bower, on Flickr
Then I thought I better see what I'm working with so set about cleaning under the front arches and washing the engine as there is a fairly significant oil leak from somewhere. This has also been highlighted by oil reading dropping by three squares in the first 1000 miles of me driving it.
Before
View attachment 188879Untitled by
After
View attachment 188880Untitled by
Before
View attachment 188881Untitled by
After
View attachment 188882Untitled by
The major leak was from the oil filler cap, with oil accumulating in the valve cover recesses. So i cleaned this, bent the prongs on the cap and reseated it.
View attachment 188883Untitled by
View attachment 188884Untitled by
So far, so good, that's one leak fixed.
It also appears to be leaking from the oil cooler and filter housing so new gaskets are on order along with gaskets for the valvetronic and some other thing I can't name. I need to get under the car to check the state of the sump gasket and will do so ASAP.
I've also noticed movement in the front suspension, upon further inspection it would appear that both front top mounts are severely cracked so new ones have been ordered to replace those.
View attachment 188885Untitled by
Also, I am trying to narrow down some clunks and bangs from the back when pulling away. The first one was the battery hadn't been tied down and is the wrong size sliding around in the tray, the other one seems to be coming from the diff but I will confirm ASAP.
View attachment 188886Untitled by
So far I'm enjoying the car, it's great fun to drive, although the EPS is pretty pants. I covered 500 miles in it over the past two days and it's not the most comfortable car for me. The seat is as far back as it can go without squeaking on the plastics and the pedals are still too close to me to be comfortable. Defo some more remedial work to complete to get it up to my standard mechanically but that's kind of par for the course with buying a secondhand car I guess.
Plans for the car change on a daily basis
but at the moment it will be the following hopefully fairly quickly:
Plated 1.5 way LSD with lower FD
Brake pads, fluid and lines upgraded
Coilovers
Square setup of wheels and tyres with semi-slicks
Induction kit and remap
Track alignment
Currently the wheels are up for sale to fund the next set.
I'll try to keep this updated as best as possible
