Reviving a Neglected Z4MR
I felt like the car was now safe enough for me to have a proper drive through the Oxfordshire countryside and see what it was all the fuss was about - and this was the point that changed everything for me. The engine, the noise, the roof down - I just had this moment where I said "why didn't I get one of these years ago??".
I had that same realisation the first time I had an unaccompanied drive in an M - I just knew I had to have one in my life and more than 6 years later it still feels special every drive. :D
You've improved it plenty already - if you carry on like that it's going to become one of the most pampered MRs around!
When I test-drove mine, the salesman had a slightly different revelation as I ran it up to 8,000rpm on motorway slip road!
Great work OP, I'm looking forward to watching your progress.
Man, i really enjoyed that read.. your interior is pretty bloody awesome, carbon leather for the win. :D very nice.
Very awesome coming together project. just lovely. Keep up the good work.
Thank you for the kind words. I've edited the original holding posts as a sneak peak of what is to come! And also added some more of the work to the thread. :D
That's interesting reading about your bearing shells, which looked remarkably clean for that mileage. 6 of mine were showing copper when they were replaced at 78K miles, but my car did have 7 previous keepers and that's one of the reasons I had them replaced!
I had mine done by Ross at RBM Hampshire who set up on his own in 2019 after 15 years at Sytner, and he also fitted ACL shells but standard bolts so it's reassuring to read that you got the same advice. :thumbsup:
Yes I was surprised that they were that clean too, you almost want them to be knackered to justify all the stress and work!
I concluded at this point that the car had not had a very hard life, or atleast the previous owners had been mechanically sympathetic which was reassuring.
It sounds like you caught yours at a good time and reinforces that the only way you really know is to get them changed. As you say, the ACL & standard bolts seemed a very robust combination!
Knowing how people like photos on here I suppose I ought to add one of my shells. TBF I have seen worse even on lower mileage cars.
Very I interesting read and impressive work. I have to replace the diff seal but that just seems to challenging for me
Interesting, definitely starting to show signs of wear. You timed that just right by the looks of it and I'd say money well spent. Much more along the lines of what I was expecting mine to look like.
Nothing is overly complex but it is a bit of a faff and no fun on axle stands on the driveway.
Just make sure if you do decide to do it that you mark the input shaft nut before you remove it and do it back up so that the lines you made match. Ensures that the preload on the bearkng is correct and you don't wear things out. Take your time too when removing the old seal so you don't leave a nice gouge in the diff housing. I'd also suggest marking the CSB before removal which negates the 5mm preload question or not.
Yes, I was glad I had them done as mine was always intended to be a keeper.
Mine has had a slight leak from the diff input seal for a couple of years - I'm probably just putting off the inevitable!
