A minor first world issue I’ve finally turned my attention to..so far..unsuccessfully..
All E89s should drop their roof on the key fob…mine doesn’t…
Cars like mine with Comfort Access option should be able to close the roof on the fob..mine does.
Roof opens ok on internal cabin switches.
Now spent two pretty full days trying to troubleshoot it..
No fault codes no other issues all sensors check out ok, re-flashed the roof module ..zippo..
So we suspect it may be the roof module in some way..
Second hand one arrived..in good condition..next step…
View attachment 296949View attachment 296950View attachment 296951View attachment 296952View attachment 296953View attachment 296954
Mine opens using the key fob but doesn't close on it
Have you got the details ?
I bought an antiglare screen protector for a 10" tablet on ebay then cut it to fit screen size in car (approx 1mm smaller all round). Cleaned screen and removed dust then fitted antiglare with the help of some soapy water, used bank card to squeegee out air bubbles. Not perfect but 100x better than damaged oe coating.
Not sure if it’s been mentioned before but have you checked all the settings/adaptions with NCSExpert?
Perhaps one has been unticked.
we've been through everything and in the end did a factory recode to reset the CTM..so the unit is on stock settings as it came out of the factory..it used to work...still have a sneaky suspicion that the comfort access door handles have something to do with it..will swap the CTM soon..
Well put the ‘new’ CTM module in…no change ..Claude and I are going to look at the FRM tomorrow..
I’m sure you have a new battery, or have tested voltage?
I've not gone back through your log of the process, but it doesn't work if it has a bad battery.
AGM battery fully charged maintains 12.4 v under full load for hours , sitting at 14.4V on charger when trying to operate..happily closes roof no issue..
I will check SoC tomorrow
