Have you got the details ?Fitted anti glare screen protector to iDrive screen... original coating been damaged by cleaning liquid by previous owner.
Mine opens using the key fob but doesn't close on itView attachment 296949View attachment 296950View attachment 296951View attachment 296952View attachment 296953View attachment 296954
A minor first world issue I’ve finally turned my attention to..so far..unsuccessfully..
All E89s should drop their roof on the key fob…mine doesn’t…
Cars like mine with Comfort Access option should be able to close the roof on the fob..mine does.
Roof opens ok on internal cabin switches.
Now spent two pretty full days trying to troubleshoot it..
No fault codes no other issues all sensors check out ok, re-flashed the roof module ..zippo..
So we suspect it may be the roof module in some way..
Second hand one arrived..in good condition..next step…
As stated above..all e89s should open on the fob..only cars with comfort access or after market modules close on fobMine opens using the key fob but doesn't close on it
I bought an antiglare screen protector for a 10" tablet on ebay then cut it to fit screen size in car (approx 1mm smaller all round). Cleaned screen and removed dust then fitted antiglare with the help of some soapy water, used bank card to squeegee out air bubbles. Not perfect but 100x better than damaged oe coating.Have you got the details ?
