Managed to import the daten files. I've now got a list up when choosing ZUSB.Use the alternative method. In WinKFP select SBL264 and then the part number ending 8087. Don't worry if this isn't correct, it will work it out for itself and tell you what part number it is going to code the module to.
Try 8087. Even if it’s correct it sometimes doesn’t work so then go the sbl264 routeManaged to import the daten files. I've now got a list up when choosing ZUSB.
The sbl264 only has 2 options, 6962877 and 6974366.
The part number ending in 8087 is under Sbsl85, should I choose this one?
I've got soo far up to the point of using Tools32, everything works so far. My B pillar module is part number 6974366, I have tried to go through the last stages in tools32, but keep getting an error...Try 8087. Even if it’s correct it sometimes doesn’t work so then go the sbl264 route
Not quite sure what you mean by D_sbsl2 module?Today's update. Using tools32, I no longer get the ECU error message, I'm now getting error_argument when using system zeit_starten. I have tried both arguments 1 and 0 after inputting 1 on system zeit_lesen.
I am using D_sbsl2 mobule
Any ideas please?
