I have changed/edited the title so as to keep it together (right or wrong)
Will now post the after I have fitted the B12 kit question at the end of the thread so it makes sense (maybe)
So after a few weeks of ownership I have done the following
Returned to stock air filter system (I know some would have kept the GruppeM, personal choice)
Changed the engine oil and filter
Changed the gearbox oil
Changed the diff oil
Changed the power steering fluid
Changed the coolant
Changed the cabin filter (I wondered why, when upside down in the footwell as well it's a roadster)
Brake fluid
Two front brake callipers
Full Vanos service by Mr Vanos
Checked loads of little bits
Drove it a bit as well
So there are two big jobs on the radar to do as I see it, one is a winter job the other a weekend job Change the big end bearing shells and upgrade the oil pump as recommended by Mr Vanos the other is a suspension refurbishment.
So to this end I have searched the forum and a popular choice is the Bilstein B12 kit and for the Z4M this is a set of B6 shocks and a set of springs.
Or stay OEM I have some H & R springs all round so the car is 25mm lower that stock. Not sure this is the best set up as a lot of people suggest leaving the ride hight OEM.
Would the H & R springs go on the B12's saving the cost of springs?
Also those that have fitted the B12 kit what else would I need to fit a complete unit as apposed to just the shocks and springs.
i.e. top mounts/top bearings.
The reason for doing the suspension is preventative maintenance as my 1 series had a strut fail around 90,000 and my Z4M has done 82,000
Thanks Paul.
Changed the coolant
Brake fluid
Thanks Paul.
