Hi All,
I had an issue over the christmas period with the engine making a load clattering on startup for about a second before it dissapears. I check the following before turning the issue into a winter project.
Checked:
Vanos
DISA
sparkplugs
water pump
pulleys
ICV
Hydraulic lifters
So in the end after not finding the fault its an engine replacement!!
So now whilst the engine and gearbox are out I'm replacing the following:
Water pump
Thermostat
Hydraulic lifters
Cam chain & tensioner
Timing chain tensioner
Duel mass flywheel
Vanos unit as my original i had recently changed the O rings
Clutch
Exhaust manifolds
block & head (using my cams) paint engine
oil pump nut drilled and wired
sump & gasket
clean engine bay
Checked:
Vanos
DISA
sparkplugs
water pump
pulleys
ICV
Hydraulic lifters
Water pump
Thermostat
Hydraulic lifters
Duel mass flywheel
Clutch
Exhaust manifolds
sump & gasket
clean engine bay
