axelleveau said:The exhaust looks amazing! You got to record some videos
Did a couple of flybys to give you an idea . Will try and get some better videos done .
[youtube]KTPcfi78mAE[/youtube]
[youtube]vIlmqrGnplM[/youtube]
Ed Doe said:Bravo!
1536Z4 said:id a couple of flybys to give you an idea . Will try and get some better videos done .
Mr Tidy said:That sounds great.
:evil: 1536Z4 said:I have been looking into running throttle bodies or just cutting off the original runners for a while now but all the posts I have seen ( mainly USA ) have not come to anything until now . This however looks promising .... https://www.youtube.com/shorts/9-xE2tBTsTA . :evil:![]()
Ed Doe said:You'll probably find by removing the standard Inlet Manifold with the twin-stage DISA and replacing with trumpets that you'll suffer from a reduction in low-end torque, but you may end up with a bit of gain at the top end!
True-Blue said:I bet it sounds amazing in real life
Ed Doe said:Fair shout you've clearly done your research
1536Z4 said:Speaking of research I will be looking for a new set of wheels in the new year and have been looking at Apex EC7 ( that I see you have ) and Arc 8 `s plus the Advan GT premiums shown here https://www.tarmacsportz.co.uk/advan-gt-premium-18x9-5-et12-5x114-3-wheel-c-5-face-73mm-centre-bore-racing-titanium-blue.html . I would appreciate your views on the EC7 and why you went for them against the ARC 8 . Thanks![]()
Ed Doe said:I went for the ec7 simply because they were on the car when I bought it
craiginuk said:Drone at motorway speeds could also be the diff ratio. Since swapping to your 3.64 the drone I used to have on motorway has reduced.
1536Z4 said:bigwinn said:I was going to use iPhone but it says that you can’t use that for the e86
This says it can be used for e series cars for xHP https://www.mlperformance.co.uk/products/mhd-universal-wifi-obdii-flash-adapter
bigwinn said:I've bought the software and spent the last week waiting for the wifi adapter- which doesn't bloody work on an e86
1536Z4 said:bigwinn said:I've bought the software and spent the last week waiting for the wifi adapter- which doesn't bloody work on an e86
Thats a pain espaecially as it says it works for e cars . I hope they pay for the return postage considering the false description .
I had no problems downloading the program and setting it up on windows 10 and that is on my old laptop . All I can advise is to go through the instructions again just in case you missed something as I have done this before thinking I had followed everything correctly .
