Z4 Coupe to Z4M Coupe Questions?
Jembo said:
Bought mine knowing the MC’’s competent but not the fastest nor best handling car on the planet, but for more emotive reasons...
- the very last M car of what’s becoming the nostalgic benchmark, manual, a Coupe & normally aspirated
- its Bangles flame surface shape
- the raw & ragged way it involves you every time you drive
- its sound
- benefit of a LSD even if a bit intrusive
- its reliability (when looked after & compared to similar marque bhp output cars)
- the minimalistic though highly focused driver layout interior which in leather still looks fresh today
- its increasing rarity
- my wife hates it so ....
- thinking if Steve McQueen were alive today, he’d probably have one in his garage
:thumbsup: :thumbsup:
Similar to me, I was well aware of it's reported flaws but I don't care, the rest of it, as you've listed, more than makes up for it. Also, having upgraded the suspension, improved the gearchange and fitted a Gruppe M, I love it even more. :driving:
ph001 said:
Peak torque to weight ratio (higher is better)
3.0Si - 0.181 lbft/kg
Z4M - 0.186 lbft/kg
E46 M3 - 0.167 lbft/kg
You can see how close the N52 and S54 are. But perhaps also as important is at what rpm peak torque is:
S54 - 4900 rpm
N52 - 2750 rpm
Of course, acceleration figures stem from power/weight, not torque (common misconception). So even with 50kg extra the M is faster due to it's added 78hp. :)
No, assuming the same gearing, accelerative G comes from torque to weight ratio, not power to weight ratio (although in essence if you are looking at any particular rpm they are the same thing as they are linked by a constant which is 5252). You have to look at the whole power curve to determine which will be quicker to a particular speed.
It's only more top speed that comes from more power.
The M revs considerably higher and holds on to it's torque better than the N52 above 5000rpm so if you are saying perhaps 0-60mph it wins. Conversely if you said 30-50mph in 4th gear, the N52 would probably win.
I would drive the Porsche and Z4M.
I think all non turbo 997 regardless of gen 1 or 2 or manual/ auto transmissions can suffer from Bore score. Perhaps look at early one with a rebuild to take care of the problem. I had a 996 turbo S once and that really handled like it was on rails :driving: The 997 is meant to be better. Incidentally, If you get a standard gen 2 997 with PDK, I think the road tax is also around £300 a year vs £500+ for the Z4M or 997's. Get the one your heart tells you to get and enjoy. Good time of year to be buying too :thumbsup:
The gen2 997 are a totally different engine (DFI ) & to date borescoring has not been recognised as a issue though other possibly routine fails are beginning to surface suggesting they may not be as bulletproof buy over the gen1 cars as previously assumed by many .
There is a thread running on 911uk regarding injector problem / coked up valves which has resulted in engine out to determine :cry:
Link for anyone interested http://911uk.com/viewtopic.php?t=136674
- its sound
Ditto... it turns an angry car into a more manageable weapon
So the question is will you ever now return to the M fold?
I'm afraid that is incorrect.
Hence for example why a diesel car with more torque but less power, then the petrol version, is indeed slower 0-60mph.
Of course, with the S54 narrow powerband you have to "shoot straight" and match it to use it.
I would never say never but highly unlikely to return to any Z of any designation & the M2 against a similar priced 911 isn't a option id consider either :(
can only see me navigating my way through the Porsche market for the forseeable future , most likely a 981 Cayman next spring , then back to 997 with a gen2 year after or possibly even a 991 depending on where they are price wise over the next 2 years .
You are being over-simplistic. The only reason diesel cars tend to be slower to 60 is that they cannot maintain the high torque over a very wide rev range. In terms of acceleration force (or G-force if you like) from 2000 - 4000 rpm they tend to wipe the floor compared to na petrol engines. Like I said earlier, you have to look at the whole power curve to determine which will be quicker to a particular speed.
I believe the OP was referring to top speed, not acceleration.
Power & drag are the two primary factors to top speed
ph001 said:
Mr Tidy said:
That's interesting, but after my drive in an MC on Tuesday to me it felt more keen to get moving well before 5,000 rpm.
Assuming similar gearing, the 'seat of the pants' acceleration force comes down to the torque to weight ratio. I did a few stats on this in another thread which showed very interesting results:
Z4M - 0.186 lbft/kg
S54 - 4900 rpm
N52 - 2750 rpm
What really stands out here is how low down in the rev range the N52 makes peak torque, in fact that is truly exceptional for a normally aspirated engine and I doubt there is another na engine in the world that makes peak torque so low down. Looking specifically at that point in the rev range:
S54 @ 2750rpm = 220lbft / 115bhp
N52 @ 2750rpm = 232lbft / 121bhp
...but also remember that M is at least 50Kg heavier and the difference becomes even more pronounced - the N52 is the clear winner.
As mentioned above, all the S54 gains are after the second vanos changeover point around 4500rpm. Fundamentally it only really makes more power because it revs higher, but I agree it's all the more exciting for it!
Though it is always nice to read the figures and do the math, it misses the very real world point. As soon as you want to have a bit of fun on a good road, you natrualy head straight for the engines sweet stop and try and keep it there as you change cogs. :driving: Point being no body drives at 2750 rpm when they are having fun. Handy on the commute to work. :thumbsup: Worth noubt once your on it, then it's all about power. :wink:
As a 'bit of fun' at the Ring, we have a challenge to see whether we can do the whole lap in a single gear (once under the gantry of course).
1st/2nd/3rd are useless as you can't get above 105mph, 6th is useless as it won't pull up the long hills, 5th is almost perfect except for one or two corners where you drop to below 50mph.
4th is the winner if you really had to drive the whole circuit in one gear.
The other 'fun' exercise we do is to artificially set ourselves a specific RPM limit - so no more than 3000/4000/5000/6000/7000rpm.
7000/6000 is easy and is like driving a 3.0 or an e34 M5, with plenty of torque/power over a few 000rpm, 5000/4000 means forever changing gear to use the bit of extra power. 3000 is doable, but you lose the 'rocket' effect out of corners as you never get into peak power curve.
The upside of all of these 'fun exercises' is that it shows how much difference the right gear makes to the performance and the fuel economy (as low as 6mpg, or as high as 14mpg) :P
It also shows you don't have to drive at 10/10ths on track to have 'fun'.
Also its sometimes more fun in a less powerful car on any track, you're bound to use all the power available. :)
I'm having great fun in my Fiat Argenta (145hp) even on Nurburgring
The throttle pick up on the S54 is very good. It does make it seem a lot pokier than it actually is, especially if you’re up in the rev range and already holding a bit of lateral G (terrible idea on a wet day, I know...).
Sounds like you may already have tried that Idea out in the wet. :wink:
I don’t think there’s a MR or MC owner that hasn’t :roll:
Yeah, maybe not mid-roundabout but certainly coming off them with no TC in the rain!
You are actually defining what ”power” is: torque x revs. :)
That is a really bad analogy of the point I think you are trying to get across. ph001 is quite correct in what he says.
Lost in translation :?
