aquazi said:i originally wanted to buy a coupe (as i already had my convertible fix from my previous S2K)
However after i saw the roadster side by side to the coupe i knew i had to get the roadster.
mistakes happen, don't worry
2low said:The Coupe is NOT more exclusive, I hate that word, makes whoever uses it sound like a right pretentious so-and-so. You are just less likely to see one seeing as there are less about.
Reggie-g75 said:Unless you have chosen a career path in Beauty Therapy or Hairdressing, you have to get a Coupe.
Best wishes, Andy Gray xx
XYZ said:2low said:It all depends whether if you are one of those chaps what is comfortable being seen in a convertible, seeing as you own an MX5 this shouldnt be a problem.
I'm female.
XYZ said:Hi Guys,
My original thread here for you:-
http://www.z4-forum.com/forum/viewtopic.php?f=2&t=20664&p=292570#p292570
I'm back and I think I'm finally ready to take the plunge this year, and I've got some questions for you all:
3. I'm looking at an M Sport. What are the must have options? I'm not too fussed about sat nav or bluetooth, but I would like parking sensors and cruise control.
All 3.0ltrs came with m-sport suspension,while qt a few were specced up with m-sport seats too. certainly worth looking for,imo![]()
7. Are there certain things to look out for at certain mileages? For example wear and tear?
Just try and find out from prev owner(s),if it had its rear coil springs renewed. a common fault. costs about £80 per side,plus fitting to renew/so not too dear.
9. How is the standard hi-fi and is it easy to connect an ipod to it? I really can't be bothered with CD's in the car anymore.
I found the std stereo lacking for me(as have history in prof car hifi installs),as it lacked depth;but plenty ppl like it ok.
U got 3/4 options. Look for an amp in the boot,and subs,etc(10 spkrs),and u wil have either the Carver or similar option,which comes with dsp. it sounds great
As for I-POD kit,plenty go for Intravee/Dice,but i like the BMW one,as its only £100-£150(depending on what stereo optn the car has),and is a fairly easy diy fit,and tho more basic in its functions than some kits,u can be limited to what u can get,if u have dsp.
10. How much will new tyres set me back (something decent, like Bridge Stones or Michelin - looking at MV2 rims)
18" Vredestein tyres are about £470 fitted(buy from elite or camskill,get ftd urself),and are Superb/espcly in the wet,and way outlast any other brand,mileage-wise!![]()
13. Any other tips?
Get a stuby(aerial,that is),lol.
Plus,108 split rims look great,but require a bit extra tlc to keep looking good/are prone to corrossion btwn the 2 sections/as are splitrims ftd to porsches,etc too!!
just check any wheels closely,and u will be fine![]()
Hope this helps![]()
BTW I'm not looking at the Z4M Coupe, just the normal 3 litre.
Part of me thinks I'll miss having a soft top, but the coupe is just way more stunning in my opinion and a bit different.
Thanks all![]()
I'm female.
many people believe you can't see with the halogens but I have no trouble.XYZ said:Reggie-g75 said:Unless you have chosen a career path in Beauty Therapy or Hairdressing, you have to get a Coupe.
I guess I'll have to get a coupe then.
On another note, how vital is it to get xenon lights? Do most come with xenon's or is it going to be listed under extra options? Also how on earth can you tell that a car has them without switching the lights on?
Z4coupebeaver said:You will be amazed as to how cheap a 3.0Si is to run.
Reggie-g75 said:The only slightly annoying issue I have is the headlight washer which throws foam all up my bonnet.
