Hi everyone,
I have a 2005 Z4 E85 who's central airbag module went out due to water. I ordered a module and got it installed and went to program it following this forums instructions https://z4-forum.com/forum/viewtopic.php?t=115539
Unfortunately I hit a major snag along the way and am reaching out for help. When doing the step using WinKFP: "Edit VIN and Flash Module" I was using the physical module for both the original and the new module have a model number of 6939810 which I believe correlates with selecting 6962766 in WinKFP. I selected Sim85 in ECU family, then selected the ZB number as 6962766 and kept Unverbaut selected for integration position. I proceeded to enter the full vin and click program. I was met with an error code which is attached as a photo. Upon evaluation, I found that I no longer had communication with a few other modules on INPA. and a different code reader shows me only the last 7 of my vin when it originally showed all 17 on the reader and only talks with around 5 modules instead of the normal 10-12.
As of current I am assuming that the programing failure and error caused a different module to have communication issues but I don't know enough to not cause greater issues trying to diagnose and fix the issue.
I am almost ready to take it to a mechanic but am concerned that it will be very expensive and I don't have a ton of money to go around.
Any help is greatly appreciated!
Thanks, Joe
Thanks, Joe
