Deepseaskateboard said:There is an updated wiring loom which can be fitted.
What is that?
I love these web recommendations about things, that one have never dealt with before.
RobbiZ4 said:Deepseaskateboard said:There is an updated wiring loom which can be fitted.
What is that?
I love these web recommendations about things, that one have never dealt with before.![]()
Deepseaskateboard said:RobbiZ4 said:Deepseaskateboard said:There is an updated wiring loom which can be fitted.
What is that?
When mine was fixed, the BMW tech said they fitted a revised wiring loom. It’s a pre LCI car, so it’s probably already fitted to newer cars.
It was a fault on one of the microswitches on the roof arms.
I will see if there is a part number on the invoice.
But I need to dig it out…
warmasice said:Ok, so here's an update..
I came home from work.. roof was down. I pressed button to close roof. Boot opened an inch and got the red light and error message on the dash 'Roof system!' with a red light on the button and bonging.
warmasice said:Deepseaskateboard said:RobbiZ4 said:What is that?
So was it the wiring or the micro switch that was replaced?
What is that?
Deepseaskateboard said:I think the wiring is also a little longer so it isn't under as much stress.
If your car is LCI, then it’s probably already got the updated parts, but not sure.
To be honest, you should know that exactly.Deepseaskateboard said:To my knowledge, they replaced both.
warmasice said:I'll check the wiring with the roof up by removing the cloth tape and see what I can find.
Ah ok. I was thinking of taking a look at the ones at the edge of the roof as seen here at the 10min mark: https://youtu.be/3q52HtkK6mU ...I know that's a very specific scenario but I think I'll take a look anyway, just to eliminate it if anything.RobbiZ4 said:warmasice said:I'll check the wiring with the roof up by removing the cloth tape and see what I can find.
Broken wires in the roof shell are difficult to identify visually without dismanteling the roof shell.
Yes, there are 2 on the right, none on the left.warmasice said:Just to confirm, there are two hall sensors on the right ram, correct? Can they be cleaned at all?
Yes, just meant if rusty. Thanks, I'll take a look at the link my friend.RobbiZ4 said:Yes, there are 2 on the right, none on the left.warmasice said:Just to confirm, there are two hall sensors on the right ram, correct? Can they be cleaned at all?
What dou you mean with "clean"?
They have to get removed for checking, replaced with new ones if rusty, nothing else.
Here is a link to pics:
https://z4-forum.com/forum/viewtopic.php?p=1921079#p1921079
Well, in this special case it means, that it's electromagnetical functionality is destroyed and it doesn't work anymore as intended. This can't be cleaned and has to be replaced.warmasice said:Yes, just meant if rusty. Thanks, I'll take a look at the link my friend.RobbiZ4 said:Yes, there are 2 on the right, none on the left.warmasice said:Just to confirm, there are two hall sensors on the right ram, correct? Can they be cleaned at all?
https://z4-forum.com/forum/viewtopic.php?p=1921079#p1921079![]()
What is that?
RobbiZ4 said:No, part B61 is a short cable adapter for this microswitch coupling fastener to support an improved plug(!) format.
That has nothing to do with the critical and expensive hydraulic harness in the roof, we are always talking about (and where the sensor wires will break). It cost's more than 1.000 Euros (54377311084). 8)
https://www.realoem.com/bmw/de/showparts?id=LM51-EUR-05-2011-E89-BMW-Z4_30i&diagId=61_4719#61132359999
Deepseaskateboard said:RobbiZ4 said:No, part B61 is a short cable adapter for this microswitch coupling fastener to support an improved plug(!) format.
I was meaning wiring, not hydraulics!
It’s expensive if they go awry.
So this is an adapter which allows the old wiring to be connected to a new version microswitch?
