Wobble under braking
Tomsdad
So there is no wheel wobble while driving. But occasionally when you brake you get a strange sensation. Sought of like what a warped disc would feel like. The usual suspects have occurred to me but the fact that is only there occasionally is making me doubt myself.
Any help appreciated.
Regards
Tomsdad
I had this and it was an intermittent problem so I was 95% sure it wasn't a warped disk as sometimes it didn't happen and it turned out to be a sticky brake caliper on the front.
Same, felt like a slow pulsing sensation when bringing the car to a dead stop - possibly exacerbated by a slightly warped disc.
Picked up as an MOT failure (binding caliper) but I had a fresh set of refurbished calipers fitted and the problem went away.
I have just had the same problem occur driving through France, on the ferry now but will check it out in the morning, had a similar problem last year when I just bought the car and it then got gradually worse until the calliper completely seized solid. This time it feels slightly different as in when I’m braking slowly coming to a stop it feels if the brakes are going on and off but very lightly but at speed the the shake gets worse the higher I go.
I checked the temperature of each wheel several times after this occurred. No noticeable difference. Don't think disc is overheating as it starts straight away when leaving a motorway. So brakes should be stone cold from doing motorway cruising, then on slip road as soon as you start breaking you get the sensation.
I believe our cars are well known for getting a sticky left hand front caliper, I experienced this on the M25 and was able to pull off quite quickly but the heat coming off just that wheel was quite alarming.
I have just posted on the discussion thread that I am just about to try getting my discs skimmed because of brake judder. This might be worth looking in to.
