Wiring help needed
This is going to be vague I'm afraid. . . .
I've change the thermostat housing unit (11531437040- on the engine) and the temperature sensor in the lower coolant hose (13621433077 - to the left of the thermostat housing) and I've noticed the plastic protective shielding on the wiring that goes to both sensors has deteriorated and become brittle - it just crumbles when you touch it leaving the wires exposed.
I cannot see the wiring on Realoem to buy a new one, and I'm wondering if I should just use some tape to re-wrap the exposed cables?
The car:
2003 Z4 E85 3.0 automatic
Until you can find the replacement wire. Possible could wrap with the wire heat shrink tubing?
think its this one https://www.realoem.com/bmw/enUS/showparts?id=BT52-EUR-09-2003-E85-BMW-Z4_30i&diagId=12_1094
https://www.ebay.co.uk/itm/275503265248?mkcid=16&mkevt=1&mkrid=711-127632-2357-0&ssspo=beni-e3sSdm&sssrc=2047675&ssuid=Sc4WWIg5SJK&widget_ver=artemis&media=COPY
