greg81 said:Dashcam running on battery?
That'll be fun when you get home to the airport from being away for the week, to find the battery flat.
I always come off of a switched live - i.e. fuse 8 in the Z4.
step_change said:greg81 said:Dashcam running on battery?
The cigar lighter socket on the e89 is only fed via the ignition.PHILGZ4 said:See what you meant about the fuse box!. This may sound stupid but does the cigarette lighter have power at all times?. i tried the the Cig lighter attachment first and even with the ignition off the dash cam stayed on?. dont want to hardwire it and it drains my battery?, thanks.
Thanks for that. I also just noticed this was a feed for the E89. i have a e85/86 model but think its still fuse 7 but not sure if its fed via the ignition. I emailed Nextbase and they mentioned the parking guard and will cut off.AnubisZed said:The cigar lighter socket on the e89 is only fed via the ignition.PHILGZ4 said:See what you meant about the fuse box!. This may sound stupid but does the cigarette lighter have power at all times?. i tried the the Cig lighter attachment first and even with the ignition off the dash cam stayed on?. dont want to hardwire it and it drains my battery?, thanks.
As above use Fuse 8 for the dashcam normal power and if you have parking guard then wire that to fuse 77.
My cam with the Parking Guard is voltage dependent (you can set this via the Parking Guard box), thus if it's parked for some time and the battery level gets too low then it'll shut itself down. Certainly the way mine works is that it'll be on all the time but in low power mode and be recording in timelapse mode until it detects a bump then it'll save the footage properly.
On the e85 the cigar lighter is live all the time.PHILGZ4 said:Thanks for that. I also just noticed this was a feed for the E89. i have a e85/86 model but think its still fuse 7 but not sure if its fed via the ignition. I emailed Nextbase and they mentioned the parking guard and will cut off.AnubisZed said:The cigar lighter socket on the e89 is only fed via the ignition.PHILGZ4 said:See what you meant about the fuse box!. This may sound stupid but does the cigarette lighter have power at all times?. i tried the the Cig lighter attachment first and even with the ignition off the dash cam stayed on?. dont want to hardwire it and it drains my battery?, thanks.
which fuse would you say is best?AnubisZed said:On the e85 the cigar lighter is live all the time.PHILGZ4 said:Thanks for that. I also just noticed this was a feed for the E89. i have a e85/86 model but think its still fuse 7 but not sure if its fed via the ignition. I emailed Nextbase and they mentioned the parking guard and will cut off.AnubisZed said:The cigar lighter socket on the e89 is only fed via the ignition.
Take a look at the 12th post on this thread, it should help you....PHILGZ4 said:which fuse would you say is best?
Beeacon said:Phil,
I went through this same issue just after Christmas, on the thread below I've said which fuses I use. They have worked great for me so far.
Fuse 8 - Cigarette lighter - on w/ ignition
Fuse 77 - Interior lighting - Always on
VIOFO A129 Duo dashcam with parking guard 3 wire hardwire kit (switches from full recording down to low-frame rate recording when ignition is off).
https://z4-forum.com/forum/viewtopic.php?f=46&t=111268
Beeacon.
DutchScorpion said:Any suggestions which dashcam fits the e89 the best?
Could not find a topic about it
