Ah well if you do insist on abusing BMWs design criteria…The KWV3 spring and strut is shorter than stock.
Never a clever idea to drop the car do much on a road based car
I’m on KWV3’s with no issues on stock 19’s Marcoose. Now on OEM M4 437’s still no issues, or with 3 or 5mm spacers purely for vanity.The KWV3 spring and strut is shorter than stock.
The aftermarket suspension wasn’t intended to lower the ride height. But that’s how it sat after install. It’s a massive improvement to the OE suspension, though.Just shows, got to be careful lowering kits, etc.
Yes, on the list of possible solutions.10mm spacer with longer bolts will definitely work..maybe 5mm
Well, pot. You’re calling me black ?Ah well if you do insist on abusing BMWs design criteria…
Interesting. Good to know.I’m on KWV3’s with no issues on stock 19’s Marcoose. Now on OEM M4 437’s still no issues, or with 3 or 5mm spacers purely for vanity.
They’re set at approximately stock M sport ride height, if anything a mm or 2 lower but pretty much stock height. Are the rear tyres wearing more on the inside edge..?![]()
There’s not really anything to get wrong, shocks fit where they fit or not at all, same with the springs.Interesting. Good to know.
The old indie that installed the KWV3 for me was competent, but not a suspension specialist. Perhaps something is off or wrong.
Yes, the rears wear more on the inside. But have stock -2.0° camber.
Here it is. It’s lower than stock, but not much. I remember notes with Peter back when, and he chose Bilstein (vs KW) because it lowered even less.Do you have any pics of the car sitting on the ground as normal so we can see the ride height..?
Yes.Was the camber set after the K+W were fitted?
It was a very light sideswipe that caused cosmetic damage from bumper to bumper. The alignment after the sideswipe was within parameters.Has the hit pushed and bulged the liner towards the wheel?
What's left side like, might be left is closer to body as it hasn't got the wiring pushing it out.
Just have dropped a bit but 10mm spacer would be the very safe option..longer bolts plsYes.
